![]() | Home > Technical (L322) > L322 gearbox |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Are you saying you paid £1700 for a tc change recon unit?. |
smighall Member Since: 15 Jan 2015 Location: West Sussex Posts: 68 ![]() ![]() ![]() |
Mine's in at STA in Ayelsbury currently. £1800+VAT for full rebuild. Although also been told the output shaft to transfer box has stripped the splines so another 200 on top of that. |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 224 ![]() ![]() ![]() |
Yes it wasn't quite 1700.
miggit, it doesn't sound as bad as your experience the box seems faultless in comparison, its just this slight hesitancy and rumble?
Funny I rarely feel lucky but this L322 is concerned it has been great no real problems only 1 air spring in its life and this TC but..... all that can change quickly at this sort of mileage
This is only a suggestion, but it might save you a heap and it wont do any harm..... I would look at giving it a good injector cleaner treatment and see if that makes things any better....... I had my box rebuilt and after a short while it developed the 'rumble' all be it very slight, after a few thousand miles. Having taken it back to the gearbox builders and no fault found, I just put it down to another bit of the car wearing out and lived with it.... last year my engine got harder and harder to start when it was hot, and eventually it f.u.b.a.r'd its'self and it turned out to be the injectors.... When I first took the car out after the injectors, I didn't feel any rumble at all |
Well, What a nice solution that would be. I have used the forte stuff on my 90 so I might give that a go.
The Bosch agent that I used charged £17 per injector to clean and test, and this was refundable against the cost of a rebuilt injector at £135.
Top tips thanks very much |
No problems Buddy |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
just to add that the rave 'repair' manual has been added to the wiki... ... - .- -.
Ok computer stupid here, I have just down loaded the link and it went into a unzip drive and I have saved onto my computer.
