Home > Maintenance & Mods (L322) > Flexi brake line lengths and fittings?
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
Hi all,
Given that off the shelf stainless braided lines arent available for an L322, I've found a company called Hel that makes flexi lines to order. You tell them what hose length and what fittings you want and they make them up.
Can someone tell me please the appropriate dimensions for front hoses, and for the 2 flexible bits of the rear hose (I'll get some lengths of pipe made to go between them to replicate the rigid sections)
Thanks,
Matt NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #377592 15th Mar 2016 6:32pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Hi Matt,
cant help you with the front ones im afraid but i have got 2 new rear flexable hoses to fit when the weather warms up.
Peter
NB: Both sides are the same
Post #377602 15th Mar 2016 7:31pm
I looked at doing that, was going to get the rears in one piece as it was cheaper, was a lot, lot more than original pipes and my originals lasted for 13 years so didn't think it was worth it, with the modern flexi hoses there isn't even an advantage in using braided on pedal feel either... Pete
Post #377656 15th Mar 2016 10:49pm
miggit
You could talk to these peep's they are very reasonable Thumbs Up
http://www.thinkauto.com/tfe.htm
http://www.thinkauto.com/acatalog/On_line_...gs_94.html
http://www.thinkauto.com/index.html Yesterday I couldn't spell Engineer... Today I are one!
Post #377744 16th Mar 2016 1:00pm
mat777
Thanks chaps,
Can someone tell me please also what the fittings and fitting sizes are on either end of the fronts and rears?
As for the cost - it seems that SHB500124 front hoses are are £15 to £30 depending on if you go pattern or genuine - having quickly mocked up some HEL ones with an estimate of fittings from the picture of genune hoses, plus the correct length, they come to £24! Am I missing something?
 NW060
Post #377748 16th Mar 2016 1:56pm
miggit
Your missing the unique selling point of the stuff that I listed.... they sell reusable fittings, so you can make up the pipe to your required length and ends, and at the angle you want. Their own brand Moquip is under £7 per meter Shocked Granted you have to add the ends, but you could fit the ends and then run the pipe.... FYI the hose will only like bending one way... if you get the ends swagged on at the wrong angle you'll be in a world of pain Shocked As for the end fitting sizes I would ask around and try and cop hold of an old pipe so you can measure them, or try a parts supplier they might take pity Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #377752 16th Mar 2016 2:54pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
Re: Flexi brake line lengths and fittings?
I used Hel for new brake lines on my old RC30 about ten years ago.
they're still on so must be ok'ish
Post #377769 16th Mar 2016 4:19pm
