Home > Maintenance & Mods (L322) > Flexi brake line lengths and fittings? |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 500 |
Hi Matt,
15th Mar 2016 7:31pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
I looked at doing that, was going to get the rears in one piece as it was cheaper, was a lot, lot more than original pipes and my originals lasted for 13 years so didn't think it was worth it, with the modern flexi hoses there isn't even an advantage in using braided on pedal feel either... Pete
15th Mar 2016 10:49pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
You could talk to these peep's they are very reasonable
16th Mar 2016 1:00pm |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 |
Thanks chaps,
16th Mar 2016 1:56pm |
Your missing the unique selling point of the stuff that I listed.... they sell reusable fittings, so you can make up the pipe to your required length and ends, and at the angle you want. Their own brand Moquip is under £7 per meter Granted you have to add the ends, but you could fit the ends and then run the pipe.... FYI the hose will only like bending one way... if you get the ends swagged on at the wrong angle you'll be in a world of pain As for the end fitting sizes I would ask around and try and cop hold of an old pipe so you can measure them, or try a parts supplier they might take pity Yesterday I couldn't spell Engineer... Today I are one!
16th Mar 2016 2:54pm |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 456 |
I used Hel for new brake lines on my old RC30 about ten years ago. they're still on so must be ok'ish |
16th Mar 2016 4:19pm |
