Yep, been there and paid the price.
My ignition showed the same symptoms......key not turning in the lock....turns out the ignition lock was fine, but the physical lock on the steering column was not acknowledging the key's insertion and thus stopping the key turning.
I tried the drilling a hole in the ECU on the column, but it didn't work. Removing fuse 18 or replacing with a temporary switch to simulate removing the fuse will work, but only for a short time.
I ended up having to replace the column with one from the US with a guarantee. I suspect the seller refurbishes failed columns since new replacements are getting harder to find, even from LR.
Mike
