Home > Technical (L322) > Steering Column replacement
mpirie
Yep, been there and paid the price.
My ignition showed the same symptoms......key not turning in the lock....turns out the ignition lock was fine, but the physical lock on the steering column was not acknowledging the key's insertion and thus stopping the key turning.
I tried the drilling a hole in the ECU on the column, but it didn't work. Removing fuse 18 or replacing with a temporary switch to simulate removing the fuse will work, but only for a short time.
I ended up having to replace the column with one from the US with a guarantee. I suspect the seller refurbishes failed columns since new replacements are getting harder to find, even from LR.
Mike
Post #375659 4th Mar 2016 8:46am
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Also if you buy an used one (perhaps mechanic is refurbished), you have no guarentee of good function electronic ans Solenoid. You must before fitting an other column refurbish the electronic! Look in my Pictures in Gallery or album. Best rgs, Uli.
http://www.fullfatrr.com/gallery/albums/us..._002~3.JPG L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #375663 4th Mar 2016 10:05am
zetjester
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
[quote="mpirie"]Yep, been there and paid the price.
Ive had this problem too...a real pain in the b** :blub:
Post #377346 14th Mar 2016 12:45pm
