Home > In Car Electronics (L322) > How to... Fit Android Head Unit to 2002-2005... |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
9th Mar 2016 3:36pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8314 |
Seems like lots of places are making head units to fit now, curved, straight, Android, WinCE, the list goes on and on... they will all be pretty much the same to fit though...
9th Mar 2016 5:50pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
But you wont get the can bus to talk so the steering wheel option is out the window Yesterday I couldn't spell Engineer... Today I are one!
9th Mar 2016 6:12pm |
boatsandy1966 Member Since: 05 Dec 2015 Location: nr pagelsham essex Posts: 162 |
so whats the best option and make to buy please 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace |
10th Mar 2016 7:40pm |
Depends what you want it to do and how much you want to spend....
10th Mar 2016 7:53pm |
cheers for reply id like to spend around 1k in total any recommendations ? dab sounds good 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace |
10th Mar 2016 7:56pm |
They are only a couple of hundred quid....
10th Mar 2016 8:03pm |
cheers il have a look and get one just need a company to fit then 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace |
10th Mar 2016 11:44pm |
Check you have connected the correct wire in the boot to the can bus, there are several similar coloured wires, "Canbus to the green wire from unit,connect to the white/slate(grey)/yellow wire in pin 9 in the radio plug"
29th Mar 2016 10:15am |
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 |
I've just ordered my kit
6th Apr 2016 8:21am |
Says it in there somewhere, you need a 5mtr aerial extension lead... loads on ebay.... Pete
6th Apr 2016 1:27pm |
thanks pete, my kit turned up today, suprisingly quick as it came from Germany.
11th Apr 2016 10:55am |
The sub output is on the green (ish) coloured phono plug.... there is no direct drive for the sub and it will require a stand alone amplifier to run it...... so that's one of your phono's used up Yesterday I couldn't spell Engineer... Today I are one!
11th Apr 2016 5:01pm |
There are a lot of wires going to the sub... easiest would be to follow them to the sub itself and see what's going on, it'l be down to two wires at the speakers themselves....!!!
11th Apr 2016 6:12pm |
