Home > Maintenance & Mods (L322) > Rear washer leak repair - the cheaper option! |
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 114 |
Well I looked at doing this on mine but the wear on the shaft made me dubious that a new seal would work. In addition the fitting on the outside was cracked so the water ran out under the cap instead of spraying from the nozzles.
27th Feb 2016 8:50pm |
Finally got round to uploading pictures.
10th Mar 2016 3:34pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
A little tip for anyone fiddling with the rear wiper.
10th Mar 2016 3:47pm |
uzp315 Member Since: 19 Nov 2017 Posts: 428 |
Having sealed a hundred leaking things on-board boats with sikaflex I have to ask - has anyone tried using a sealant and putting a thin bead around the existing grommet? I can't see why this wouldn't work, and it would barely even be noticeable. Tempted to have a go myself. If I do, I will report back.
12th Dec 2017 9:45am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
SausageCreature, the wiper shaft turns within the seal, loading it up with silkaflex or similar will no doubt seize up the shaft once its set 2007 TDV8 VSE
12th Dec 2017 10:43am |
Mm..I need to look at this a bit closer. AFAIK, mine is leaking in the same place as the OP photos, from around where the black plastic/rubber meets the metal on the inside. This doesn't turn - surely it doesn't turn otherwise the whole hose feed would be wanging around inside the rear door everytime the wiper was swtiched on. |
12th Dec 2017 10:46am |
Ok, Wayne so it is worse than I thought in that the leak is inside the unit and just happens that the water leaks out as well as into the internals of the motor? OR is it just a leak that leaks out? If it is, then sealing the outside would be ok, wouldnt it ? |
12th Dec 2017 10:50am |
The wiper motor shaft turns within, if yours is leaking to the outside of the seal, block that up and the water will go into the motor gears and seize the motor. From your previous post, I thought you were thinking of adding sealer to the inside instead of replacing the seal.
12th Dec 2017 10:55am |
Dang. What a pain. Ok. Looks like I need to order the rubber grommit that the OP identified and do the job properly. |
12th Dec 2017 10:57am |
It's not that bad a job, 20 mins to have it out and on the bench for me then time to clean grease etc. Taking the spoiler off takes 5 mins max, the inner trim the same and just a few screws and its off. 2007 TDV8 VSE
12th Dec 2017 11:18am |
Bought one... time to bite the bullet I guess....
12th Dec 2017 11:20am |
Yeah, it doesnt look too bad, it's just cold here at the moment, and after a few winters at sea my hands have never been the same - the cold just splits them open at the end of the fingers and thumbs making me reluctant to do jobs like this in the cold. Still, the FF comes as first priority Update: All done/ very easy. Fingers crossed it lasts. Last edited by uzp315 on 17th Dec 2017 4:29pm. Edited 1 time in total |
12th Dec 2017 11:22am |
FrankN Member Since: 11 Feb 2017 Location: Vellmar, near Kassel, middle Germany Posts: 101 |
Good morning, I have made a other repairing , the water trought the gearbox is not the best , it’s a problem by many cars
13th Dec 2017 8:37am |
What jet is it you are using? This definitely looks the way to go to stop future water leaks in the gearbox plus this looks like an upgrade. 2007 TDV8 VSE
14th Dec 2017 2:25am |
