Home > General > What Did You Do In Your Full Fat Today |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
Took her on the first visit to the in laws. |
5th Mar 2016 8:04pm |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
Replaced both upper front track control arms. The offside was a dream having a coffee after 40 minutes wheel back on. Then I started the nearside. Broke my ball joint splitter. Borrowed a scissor type that I took to the limit lots of plusgas and had to go and pick splitter up from where it landed, lost my temper so off to the shed for the big hammer and breaker bar.
5th Mar 2016 9:19pm |
Les40 Member Since: 15 Feb 2016 Location: Coventry Posts: 36 |
Saw 3.2mpg according to the trip computer 😜 |
5th Mar 2016 9:27pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
Dismantled the rear wash wipe system due to the usual no water. Not much brown stuff in the pipe, soaked the non return valve in some hot water, unblocked nozzles in wiper arm cap and poked about in black plastic elbow where a lot of crud seemed to have collected. Result..... a steady flow thru the nozzles but a very small drip from where the black plastic elbow joins the wiper motor..... |
6th Mar 2016 5:31pm |
HGv driver Member Since: 16 Sep 2014 Location: Cardiff Posts: 169 |
fitted a new battery and gave it a wash might wax it next weekend |
6th Mar 2016 9:44pm |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 541 |
Changed the rad top hose on Sat (again!) and gave in to cleaning it on Sun. |
7th Mar 2016 10:33am |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 |
Replaced the front windscreen jets old ones blocked. |
7th Mar 2016 10:42am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
How did you remove the old jets? John
7th Mar 2016 2:03pm |
They just push out from under the bonnet. Range Rover quotes.....
7th Mar 2016 3:22pm |
Thanks. As the bonnet panel (grill) needs a bit of respraying, I unclipped it but was reluctant to try anything for fear of damage. John
7th Mar 2016 3:26pm |
I pushed mine out, they came out easy and all I did was push the new back in, connected up and works a treat. Range Rover quotes.....
7th Mar 2016 3:36pm |
John
7th Mar 2016 3:47pm |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
Finally decided on having the calipers painted. Good result I think..........
9th Mar 2016 4:42pm |
pumpkin69 Member Since: 20 Feb 2016 Location: France Posts: 25 |
i have lent it to my wife. 2007 vogue 3.6tdv8 Java
9th Mar 2016 7:01pm |
