Home > Maintenance & Mods (L322) > 2007 3.6 TDV8 Thermostat housing Replacement
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
i had three leaks and a pipe and was very mucky, just the additives making it congeal
 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #375834 5th Mar 2016 11:26am
Hammer
Australia 2007 Range Rover Vogue TDV8 Zambezi Silver
Ok put it all back together and it began to leak again, I traced the leak back to the thermostat housing.
Took it all apart again and found the oring damaged. I must have been a bit rough putting it together.
I put coolant on the oring to help assembly maybe I need a better lubricant to help it slide into place.
Any tips on how to do it without damaging the oring would be appreciated.
Paul
Post #377509 15th Mar 2016 11:20am
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Hi Paul.
I used some vaseline (petroleum jelly). Some on the O ring and a good smear around the hole in the block.
Don't worry about the slight contamination in the water/antifreeze mix, the small amount wont make any difference.
Make sure the hole is clean. I cleaned ours up with some 400 grit wet & dry as it was slightly pitted.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #377620 15th Mar 2016 8:32pm
Hammer
Thanks Steve.
Ok applied Vaseline and she popped into place no problems.
All back together and no leaks.
Paul
Post #379176 24th Mar 2016 10:28am
Dale
Finland
Good write up. Thanks for sharing! Pics are essential in this hassle. Thumbs Up
I do have a new thermostat waiting, but housing is still intact. No leaks. Car is -09/-10 model.
Post #396555 18th Jul 2016 5:25am
