![]() | Home > Maintenance & Mods (L322) > Rear Brake Caliper sticking |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8392 ![]() ![]() ![]() |
If you want to know if a good cleanup will be enough or you need to refurb, have a look at the pistons, pump them out a bit with the pedal, not too far or they may come all the way out...
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 354 ![]() ![]() ![]() |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
It's called wd40 as it was their 40th attempt at perfecting their water dispersant |
Quote from hylands - I am not sure how you get the quote to work - but here goes.....
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3873 ![]() ![]() ![]() |
ah well thats another 600 quid to the Indy |
So 600 quid wasn't quite enough, but as well as the caliper got new discs and pads on the rear, Indy confirmed that the caliper was completely seized and the piston wouldn't move back at all.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
''Good job the stock market is on the up''
Actually you'd probably have shares in Tata Motors and as you can see they wouldn't be paying for my brake bits despite the profits they are making at JLR |
Did I just Hijack my own thread - or was it Stan? |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Unstuck my rear calipers yesterday. Car hadn't moved for over 3 weeks and when braking, was a juddering from the rear. When I got home checked discs. Both were hot with the offside being the hottest. Set to work dismantling in the freezing cold. A few sweary words later both sets cleaned up and freed off. Surprised to see only one wear indicator on the offside inner pad. I had to araldite this back in place.
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 ![]() ![]() ![]() |
I am currently renewing the rear brakes, including calipers, the calipers floated OK, but the piston doesn't retracts enough and have been warming the discs, they were dure to be changed anyway.
cdocksey Member Since: 28 Sep 2014 Location: Caracas, Venezuela Posts: 15 ![]() ![]() |
When you guys mention silicon for the seals..., you mean silicon spray as for shining up the consoles? Or silicon grease (which looks like Vaseline sort of stuff)? Thanks |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3246 ![]() ![]() ![]() |
Only one on the front - nearside. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
