Home > Maintenance & Mods (L322) > Rear Brake Caliper sticking
If you want to know if a good cleanup will be enough or you need to refurb, have a look at the pistons, pump them out a bit with the pedal, not too far or they may come all the way out...
Slide back the rubber seal that sits in the groove, if the pistons look like these then it's time for a new one, if it's damp under the seal it's had it too.... or refurb them yourself for half the cost... (the part of the piston outside the dust seal will always be rusty in our climate)
I'm with Emirates777, I strip them every so often and give them a deep clean.... Mind you he uses remoulds on his company vehicle so what does he know..... :rolllaugh:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #371248 8th Feb 2016 1:21pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Haylands - good one
Point to add to Haylands that I always do
1. Ensure you USE Metal Coat hangers to HANG The Caliper up - when you have unbolted them from hub ( not pull brake lines)
2. I always put a thin piece of OAK in-between Piston and Brake Caliper (4" long) so when you pump the brake pedal in the car the piston will not shoot out. ( ensure the wood is held in Caliper / tape / gaffer tape or get someone to hold it )
3. With caliper suspended on the wire (SAFE through holes) carefully wipe ALL crap away from piston boot and if you SPRAY SILICON (NOT W40 - as this stands for Water Displacement for 40 days ONLY - and YES it only last 40 Days !!!!) - Silicon will last later - you will see any crap gets washed out and it will help lube the position boot and make things like new.
We have a DS3 from new that has 173K on and all brakes are in great condition - due to the face they get over hauled every 6 months - easy job to do if you do them often - NEVER HAD ANY BRAKE PROBLEMS EVER
REMEMBER - when pushing the Piston back in - DO NOT use a screw driver, hammer
use this: - costs around £14 called a BRAKE CALIPER PISTON REWIND TOOL
BUT REMEMBER TO UNDO THE BRAKE FLUID RESERVOIR CAP TOP IN ENGINE BAY - to let the pressure off when your winding in the Piston - this stuff is under pressure when getting compressed.
You will find that if you undo and wind in ( the process 4 or 5 times then a sticky caliper will almost be new again. )
Note: 4.4 / 5 litre BREMBO Units
The above tool is only used on rear or small front calipers
(If you have the Big Front 4.4 / 5 litre Brembo units - you have to leave caliper on hub in suitu - get a mother of all screw drivers and pries the INSIDE side brake pad towards the Piston each side. - in order to slowly push the piston in.
THESE BIG 4.4 / 5 litres calipers you can only do them in suitu. once they are HOMED IN about 4mm the pads LIFT OUT.
Then you can take off and clean the insides up. warning they weigh a tonne !!!!
Post #371256 8th Feb 2016 2:04pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
It's called wd40 as it was their 40th attempt at perfecting their water dispersant Wink
Post #371259 8th Feb 2016 2:27pm
EmiratesA380
Quote from hylands - I am not sure how you get the quote to work - but here goes.....
I'm with Emirates777, I strip them every so often and give them a deep clean.... Mind you he uses remoulds on his company vehicle so what does he know..... Rolling with laughter[/quote]
We don't do things in halves on FFRR either !
BIG IS BEST - as my GF Says
Cheers Haylands Thumbs Up
Post #371263 8th Feb 2016 2:49pm
supershuttle
ah well thats another 600 quid to the Indy Shocked apparently the calipers for my car are only available from JLR @ £288 +VAT each so they might as well do the discs and pads whilst they're at it. They did say they could free it all off but reckoned that it might only be a temporary fix - so in for a penny in for 600 quid Very Happy Geoff
Post #371883 11th Feb 2016 9:10pm
supershuttle
So 600 quid wasn't quite enough, but as well as the caliper got new discs and pads on the rear, Indy confirmed that the caliper was completely seized and the piston wouldn't move back at all.
I'm not blaming them (they did offer to try and fix but couldn't guarantee either success or permanence). No I'm blaming JLR as they appear to be the only source for the rear calipers on the 5.0l Supercharged and they charge £288 plus VAT per side (as I said above) Shocked
Good job the stock market is on the up Very Happy Geoff
Post #372895 18th Feb 2016 8:15am
''Good job the stock market is on the up''
especially if you have shares in LR.... Laughing ... - .- -.
Post #372897 18th Feb 2016 8:19am
supershuttle
Actually you'd probably have shares in Tata Motors and as you can see they wouldn't be paying for my brake bits despite the profits they are making at JLR Rolling with laughter
 Geoff
Post #372912 18th Feb 2016 9:26am
supershuttle
Did I just Hijack my own thread - or was it Stan? Laughing Geoff
Post #372914 18th Feb 2016 9:33am
MachineHead
Scotland 2009 Range Rover Westminster TDV8 Mariana Black
Cam-Tech-Craig wrote:
Is yours a 3.6 or a 4.4 MachineHead?
Mine is a 3.6 tdv8 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #372949 18th Feb 2016 1:24pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Unstuck my rear calipers yesterday. Car hadn't moved for over 3 weeks and when braking, was a juddering from the rear. When I got home checked discs. Both were hot with the offside being the hottest. Set to work dismantling in the freezing cold. A few sweary words later both sets cleaned up and freed off. Surprised to see only one wear indicator on the offside inner pad. I had to araldite this back in place.
First time I've made use of the Halfords 3 tonne axle stands. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #425027 27th Jan 2017 10:09am
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
I am currently renewing the rear brakes, including calipers, the calipers floated OK, but the piston doesn't retracts enough and have been warming the discs, they were dure to be changed anyway.
I have exercised the pistons with lubrication a couple of times, which helped, but reoccurred.
Service exchange caliper is £55 + at each at Andrew Pages.
Upon stripping the rear set up I found the handbrake setup was in poor condition so I have cleaned and painted the back plates, and carriers, new hand brake shoes, new discs and pads.
Hopefully normal service will return soon Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #425031 27th Jan 2017 10:39am
cdocksey
2006 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
When you guys mention silicon for the seals..., you mean silicon spray as for shining up the consoles? Or silicon grease (which looks like Vaseline sort of stuff)? Thanks
Post #429171 25th Feb 2017 8:02pm
Weegie
Only one on the front - nearside. John
GAP iiD BT
Post #429225 26th Feb 2017 8:47am
