![]() | Home > Technical (L322) > Td6 gear box help please |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Has your g/box been refurbed at all?.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1003 ![]() ![]() |
The solenoids can be removed after dropping the sump pan. There’s no need to even remove the valve body assembly - in fact the process is even covered by RAVE.
Superb description and reply as always phil.
Steveo Member Since: 26 Jan 2015 Location: Essex Posts: 156 ![]() ![]() ![]() |
Cheers for that phill do you think I would be better changing them all where is the best place to get them from ect I have noticed that going from 4th to 5th there is a jolt but the rest are smooth cheers |
boatsandy1966 Member Since: 05 Dec 2015 Location: nr pagelsham essex Posts: 162 ![]() ![]() ![]() |
i bought my car late last year can recommend Suffolk autotransmissions good honest guys know what they are doing 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace |
The solenoids are available from Land Rover under the following part numbers:
That would be a massive help if you could what is the best way to contact you phill cheers |
Just send me a PM and include your address.
Oscel Member Since: 15 Aug 2017 Location: Sydney Posts: 4 ![]() ![]() ![]() |
Hi Steveo,
