Home > Technical (L322) > Td6 gear box help please
Steveo
Good morning all I am looking for some help I have just been out in my car and the transmission fale safe came on so I plugged in the iidt tool and it has registered a fault it is coming up as line 4 pressure solianoid fault can any body tell me have they changed one them self and is it a easy job ect ect
Post #371372 9th Feb 2016 9:09am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Has your g/box been refurbed at all?.
Have you tried the search?.
Lots of info on here regarding the gm g/box.
you may be able to access the valve block from underneath with sump off, but I am no expert in auto boxes.
the valve blocks do wear as they are made of a soft alloy.
I don't want to be the grim reaper, so best get it checked by specialist if your not sure.
Post #371502 9th Feb 2016 5:40pm
RRPhil
The solenoids can be removed after dropping the sump pan. There’s no need to even remove the valve body assembly - in fact the process is even covered by RAVE.
Your transmission has five solenoids, three of which are identical parts. Both GM and Land Rover label them as :
A (for 1-2 shift control)
B (for 2-3 shift control)
C (for 4-5 shift control)
TCC (for torque converter lock-up control)
Pressure Control (for controlling transmission line pressure)
Unfortunately therefore I have no idea which one is being identified by your diagnostics kit as ‘solenoid 4’
Phil
Post #371587 10th Feb 2016 12:46am
gregdav
Superb description and reply as always phil.
Bow down Bow down Bow down
Post #371603 10th Feb 2016 7:34am
Steveo
Cheers for that phill do you think I would be better changing them all where is the best place to get them from ect I have noticed that going from 4th to 5th there is a jolt but the rest are smooth cheers
Post #371611 10th Feb 2016 8:54am
boatsandy1966
United Kingdom 2004 Range Rover Vogue SE Td6 Adriatic Blue
i bought my car late last year can recommend Suffolk autotransmissions good honest guys know what they are doing 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace
Post #371688 10th Feb 2016 6:59pm
RRPhil
The solenoids are available from Land Rover under the following part numbers:
A, B & C solenoid = LNN 000020 - cost approx. £70 each
TCC solenoid = THC 500050 (was TJD 000040) - cost approx. £120
Pressure control solenoid = TJD 000050 - cost approx. £190
Specialist automatic transmission part suppliers like JPAT, Sussex Auto Parts, Mackies, Vanmatic, Automatic Choice, etc. may be able to supply them cheaper.
Although we don’t know which solenoid is ‘line 4 pressure solenoid’ (according to your IIDTool) if you are noticing problems with the 4-5 upshift it may possibly be solenoid C that’s playing up???
I could certainly send you a used one to try if you wanted to attempt to identify the faulty part through a process of elimination.
Phil
Post #371737 10th Feb 2016 9:45pm
Steveo
That would be a massive help if you could what is the best way to contact you phill cheers
Post #371739 10th Feb 2016 10:01pm
RRPhil
Just send me a PM and include your address.
Phil
Post #371805 11th Feb 2016 1:08pm
Oscel
Australia 2004 Range Rover HSE Td6 Zermatt Silver
Hi Steveo,
I realise this thread is over a year old....just wanted to check if you ever solved this?
I've got exactly the same message/issue and have been trying to get to the bottom of it. I'm now at my wits end and after sifting through pages of google results, amazingly came across this!....so I'm hoping you might be able to answer it?
I'm leaning towards it being the torque converter lockup solenoid...
Post #447895 15th Aug 2017 4:23am
