Home > Technical (L322) > Car idles rough then revs drop and it stalls |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
What model, engine and year are we talking?
30th Jan 2016 9:11am |
Choppergrino Member Since: 29 Nov 2015 Location: Melbourne Posts: 14 |
It's an L322 and yes it did run before.
30th Jan 2016 9:16am |
Petrol or deisel? Size of engine and model year? These are pretty key pieces of info to anyone trying to help you.
30th Jan 2016 9:25am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
It's in his signature. plus "I am new to this forum and have stumbled upon it searching for info on L322 timing issues.
30th Jan 2016 10:22am |
I'm aware a car is listed in his signature, but when he said his brothers I assumed it would be a different one. I have better things to do than search someone's previous posts to find the quote you found. |
30th Jan 2016 12:59pm |
It took about as long as it took you to type that. John
30th Jan 2016 4:28pm |
Thanks for that. |
30th Jan 2016 5:05pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
A quick check is connector on the throttle body which is easily knocked if climbing on the engine to get over the back and gives the symptoms you describe if not fully connected. |
30th Jan 2016 5:58pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
MAF .? |
30th Jan 2016 6:06pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Enough fuel?
30th Jan 2016 6:40pm |
Thanks everybody for the posts.
30th Jan 2016 9:34pm |
Today I put new fuel in and and reset the ECU.
31st Jan 2016 9:00am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Air leak, maybe around where the inlet pipe meets the throttle body or various small pipes
31st Jan 2016 10:57pm |
Thank you holiday chicken I will have a double check.
31st Jan 2016 11:20pm |
