Home > Technical (L322) > Car idles rough then revs drop and it stalls
Choppergrino
Australia 2003 Range Rover Vogue 4.4 V8 Barolo Black
Hi everybody
I have been tinkering with my brothers RR vogue l322 on and off for a while now and after connecting the OBD to the car had a few faults I need some help with.
Jobs done so far:
- replaced timing chain guides
- replaced main timing chain
- replaced chain tensioners
- set timing chain timing with timing kit
- replaced cam position sensors
Car starts easy however it doesn't run very well, when it idles it's rough and after a few minutes stalls.
The OBE II scan on a live test shows
Fuel sys 1 : fault ?
Fuel sys 2 : fault ?
I took the fuel relay out and tested that the fuel pump was starting (and it is I can hear make noise)
I also pushed the valve on the fuel pipe on top of the engine ( fuel came out)
I have checked for air/vac leaks on hoses so far I cannot find any leaks.
Does anybody have an idea? Thanks in advance
Ps: I am trying to get the car running nice to present it to him next Friday as a surprise 40th birthday gift Smile
Post #369507 30th Jan 2016 7:42am
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
What model, engine and year are we talking?
Did it run ok before all the work on timing chains etc?
Post #369512 30th Jan 2016 9:11am
Choppergrino
It's an L322 and yes it did run before.
Thanks
Post #369513 30th Jan 2016 9:16am
kezbo1981
Petrol or deisel? Size of engine and model year? These are pretty key pieces of info to anyone trying to help you.
But of it ran before you replaced the timing chains and other work you say you have done, then first thing I would do is retrace your steps. Have you managed to somehow get the timing gear slightly off, or is the new sensor duff or is something you had to remove to get into the engine to change these not put back properly or been damaged?
Post #369514 30th Jan 2016 9:25am
Weegie
It's in his signature. plus "I am new to this forum and have stumbled upon it searching for info on L322 timing issues.
I don't own a RR, however my brother does and I have had to do some work on it of late. " Wink John
GAP iiD BT
Post #369526 30th Jan 2016 10:22am
kezbo1981
I'm aware a car is listed in his signature, but when he said his brothers I assumed it would be a different one. I have better things to do than search someone's previous posts to find the quote you found.
Post #369543 30th Jan 2016 12:59pm
Weegie
Thumbs Up It took about as long as it took you to type that. Wink John
GAP iiD BT
Post #369574 30th Jan 2016 4:28pm
kezbo1981
Thanks for that.
Post #369583 30th Jan 2016 5:05pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
A quick check is connector on the throttle body which is easily knocked if climbing on the engine to get over the back and gives the symptoms you describe if not fully connected.
Post #369592 30th Jan 2016 5:58pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
MAF .? Thumbs Up
Post #369593 30th Jan 2016 6:06pm
Clivefog
Enough fuel?
Good/new fuel?
Fuel filter need changing?
Air filter need changing?
Post #369595 30th Jan 2016 6:40pm
Choppergrino
Thanks everybody for the posts.
So the car is a 2002 RR vogue petrol L322.
The fuel is old maybe 6-8 months however I would still think it would have some spark??
A lot of hoses and plugs were disconnected at the front of the engine when we did the chains and I am working through double checking them all.
How do I check the MAF is operating correctly ?
Thanks
Post #369618 30th Jan 2016 9:34pm
Choppergrino
Today I put new fuel in and and reset the ECU.
( correct me if I'm wrong , i held the accelerator down turned the ignition on for ten seconds, then turned the ignition off and took my foot off the gas pedal)
- I charged the battery
- removed at re seated the intake ducting
I started the car and let it idle for 10 mins observing the revs and listening to the engine.
The motor sounded ok - not perfect as there was a slight tappet sound.
With a short rev of the motor in PARK it sounded good and strong, I drove it backwards and forwards a few times and the power seems normal. I am reluctant to drive it around the block as the OBD II was showing a fuel fault.
At the front of the car the motor is running reasonably good with a slight tappet noise and at the back of the car the exhaust is making more of an inconsistent noise.
I have posted photos of the OBDII in my gallery if anyone who's how to translate them into lay men's terms...
Thanks
Post #369670 31st Jan 2016 9:00am
holidaychicken
Air leak, maybe around where the inlet pipe meets the throttle body or various small pipes
Small electrical connectors that connect to each injector can get bent over when reconnecting
Post #369827 31st Jan 2016 10:57pm
Choppergrino
Thank you holiday chicken I will have a double check.
I did snap a small hard line and re connected with rubber maybe there is another hole
Post #369833 31st Jan 2016 11:20pm
