![]() | Home > General > What Did You Do In Your Full Fat Today |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
I fitted the painted handle covers I received from powerful uk .
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
^^ looks good mate. Love mine. I used a heat gun to warm up the handles real good then applied the covers. This way I didnt have to do the whole masking tape thing. 2014 FF Autobiography 5.0 SC
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 791 ![]() ![]() ![]() |
Today I cursed mine !! Returned after parking up to find that gear lever was simple gliding between park and drive and no gears where being selected. Crawled underneath to find that the cable had become detached.Waited for RAC as wasn't sure if I had lost a clip or something but it turned out it just needed putting back in a slot and tightening up ! Put it on high suspension settings which made life easier for
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Passed MOT with 2 advisories, rear brake pipes signs of corrosion and handbrake needs adjusting. Will sort these out in the next couple of months. Supercharger belt and tensioner identified as making ticking noise. Booked in to get sorted at end of next month. Overall over the moon! Previous cars:
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 ![]() ![]() ![]() |
Not done anything in mine since Monday. Wifey has pinched it until I mend hers. Says something when the FF is the most reliable vehicle (except my VStrom) in the house. |
silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84 ![]() ![]() ![]() |
Had the old bus MOT'd .Passed with flying colours. Good news for another year. |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
Suspect I picked up another 3 points |
2 over and they will ticket you? Lame. 2014 FF Autobiography 5.0 SC
If you're running stock tyres you'll be reading high on your speedo anyway .... |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Fitted the steering wheel reach nylon nut thingy that ulrich11-59 sells on ebay.
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
Changed the engine oil and filter. The job is not made easy by the location of the two sump plug drain positions.
'Passed MOT with 2 advisories, rear brake pipes signs of corrosion and handbrake needs adjusting. Will sort these out in the next couple of months. Supercharger belt and tensioner identified as making ticking noise. Booked in to get sorted at end of next month. Overall over the moon!'
