Home > General > What Did You Do In Your Full Fat Today
Page 214 of 379 <123 ... 213214215 ... 377378379>
Rafterman
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Java Black
New discs and pads front and rear (thanks to Dan) , passed MOT for another year Razz Thumbs Up The worst thing about being retired is you miss out on all the bank holidays
Post #369135 27th Jan 2016 10:18pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
I fitted the painted handle covers I received from powerful uk .
Having seen a few rovers driving around with chrome covers with missing over the years , I decided to add a little sticky goo .
The tape they come supplied with was marked 3m so should be good enough for the task , but I noticed it was peeled slightly on one handle and as they're painted with the tape applied I knew that little area would not stick .
One word of advice : inspect all the pieces first before you stick them on , as 2 pieces had a slight rough edge so these went on the passenger side facing down so it wouldn't be seen or touched when used .
I only did a trial fit on the drivers side and all seemed well , but when it came to fitting the last one on the passenger side it was faulty Rolling Eyes
Nothing big , but disappointing .
On all the other doors there is a fine gap between the cover and the handle , but on the faulty one it isn't cut parallel so it's the same small gap at the top , but a bigger gap at the bottom .
All in all I'm happy with them and they make the car look a lot better .
Especially as I got them for free using eBay bucks Smile
They come with 5 covers , so you can cover the keyhole in the drivers door , or leave it open .
I left it with a key hole even though I've never used a key in the door .
Sod's law if I covered it up I'd need to use a key ....
Post #369137 27th Jan 2016 11:47pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
^^ looks good mate. Love mine. I used a heat gun to warm up the handles real good then applied the covers. This way I didnt have to do the whole masking tape thing. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #369188 28th Jan 2016 2:17pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Today I cursed mine !! Returned after parking up to find that gear lever was simple gliding between park and drive and no gears where being selected. Crawled underneath to find that the cable had become detached.Waited for RAC as wasn't sure if I had lost a clip or something but it turned out it just needed putting back in a slot and tightening up ! Put it on high suspension settings which made life easier for
the RAC bloke.
Then it wouldn't start. Knew from a problem the day before that the battery was on its way out and had ordered another one. Jumped it and fitted battery this afternoon ( £112.00 ). Wish I had the 30 million pound lottery ticket !
Post #369220 28th Jan 2016 4:50pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Passed MOT with 2 advisories, rear brake pipes signs of corrosion and handbrake needs adjusting. Will sort these out in the next couple of months. Supercharger belt and tensioner identified as making ticking noise. Booked in to get sorted at end of next month. Overall over the moon! Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #369275 29th Jan 2016 12:03am
steadyaway
Not done anything in mine since Monday. Wifey has pinched it until I mend hers. Says something when the FF is the most reliable vehicle (except my VStrom) in the house. Shocked
Post #369289 29th Jan 2016 8:57am
silversurfer
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
Had the old bus MOT'd .Passed with flying colours. Good news for another year. Thumbs Up Thumbs Up
Post #369356 29th Jan 2016 1:58pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Suspect I picked up another 3 points Big Cry . 32 in a 30 past the little Censored in his van. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #369413 29th Jan 2016 6:00pm
ajac8
Suspect I picked up another 3 points Big Cry . 32 in a 30 past the little Censored in his van and my road angel told me he might be there.
Embarassed Embarassed Embarassed Embarassed 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #369414 29th Jan 2016 6:01pm
horse86
2 over and they will ticket you? Lame. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #369427 29th Jan 2016 6:24pm
Ian c2
If you're running stock tyres you'll be reading high on your speedo anyway ....
Post #369460 29th Jan 2016 8:24pm
Clivefog
Fitted the steering wheel reach fix
Fitted the steering wheel reach nylon nut thingy that ulrich11-59 sells on ebay.
Took about an hour and now no noise!
Also used some leather repair stuff from ebay. Instructions were gently wipe the colour matched stuff over the scratch/scuff/wear mark leave for 5 minutes and retreat if required - so good I could not see where I had applied it so had to buff the whole leather interior!
Post #369541 30th Jan 2016 12:39pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Changed the engine oil and filter. The job is not made easy by the location of the two sump plug drain positions.
I loosened the first one (nearest the front of the vehicle) until it was just about to fall out and let the oil drain for 1/2 an hour. This stopped it spurting all over the engine cradle. The drain nearest the rear of the vehicle looked like it had not been touched for years. Thankfully after draining the first one, only around 1/2 litre came out, all over the rear of the engine cradle. Oil filter replaced and filled up with oil.
Whilst jacked up and on a axle stand I decided to change the front diff oil, so started to take off the nearside front wheel, that's where my next problem started. Swollen stainless steel wheel nut covers. After 20 minutes the wheel was off, as a temporary measure I cut off the covers on all the wheel nuts.
Drained the diff oil, this was a very dark brown but clear, so no water mixed in with it, but it smelt a bit off as though it had been in for a long time.
Before fitting the wheel back I cleaned all this crud off the front strut.
This collects under the air spring bellow and can't do the rubber any good rubbing up against it.
After cleaning it.
I decided to do the other air springs and had the same battle with the other wheel nuts.
I would have thought something like this which harks back to the Discovery and P38 era would have been sorted by now.
Steve.
[/img] 1968 Series IIA Pastel Green, nearly there project
Post #369810 31st Jan 2016 8:36pm
vaz
After cleaning it.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #369813 31st Jan 2016 8:37pm
DaveK
'Passed MOT with 2 advisories, rear brake pipes signs of corrosion and handbrake needs adjusting. Will sort these out in the next couple of months. Supercharger belt and tensioner identified as making ticking noise. Booked in to get sorted at end of next month. Overall over the moon!'
appj62...Whilst searching for another FFR, I've been putting them through an MOT History check. Not a single one has come back with out the rear brake pipes corrosion advisory !!
Post #369861 1st Feb 2016 9:32am
