![]() | Home > Technical (L322) > Diesel Induction cleaning..... HELP! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Afternoon chaps, I'm looking for a method of cleaning all the crud that's built up in my induction system.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
Bear in mind, that whatever you use is going to dislodge something in the intake system, and it's only way out is into the cylinders, and out through the rebuilt turbo
I'm talking about this being drawn into the combustion chamber...
Yes I can see what you are saying.......... but it's not like I'm the first to think about this method of cleaning........ you, yourself say use injector cleaner, which I wont as they were cleaned on a rig less than 10K ago. The fact is the oil/carbon build up that is present is combustible provided that it's dissolved in a solvent. So the engine will not be eating large sticky black boulders, rather it will be running on an oil rich mix for a few minutes.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
I have done the clean-out on my TD6 before fitting the EGR blank to stop it from reforming. I have to say it was the most disgusting task I have ever done on a car. The black goo is like indelible ink whatever it touches turns black. So here`s what I did. Remove the intake manifold which is very simple. Take note of where all the rubber seal are and dont lose any down an orifice. Get some disposable rubber gloves. Once off use whatever you can to dislodge and clean the accessible areas then hit the insides with oven cleaner, the foaming type. Leave overnight then take to an area of you garden you dont like and blast it with a jet washer. I had to do this twice but the end result was a lovely clean intake and a big black patch in the garden. I also made a little scraping tool that would reach into the head and I could scrape the crud up and out with an old vacuum helping clear and bits that were ready to drop. I could not get over the thickness and amount of that disgusting muck that was choking the engine.
Air flow is not such an issue on a forced induction engine. Any gains you do see would be negligible, almost placebo |
I cant comment on placebo or not on my car as I did several things at once. What I can guarantee is that blanking the EGR, Cleaning out the intake gunk, fitting a vortex breather, a go faster pipercross air filter and a cheap ebay tuning box transformed the performance. The average fuel consumption also dropped from 12.8 litres per 100k`s to my now long term average after 10000klms of 8.6ltrs per 100kls. My car was very neglected when I got it so just changing oil and filters might have helped as well. If starting from scratch again with the car I would definitely do it again. 2007 TDV8 VSE
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
I would take out what you can, and clean it out with some diesel and brake cleaner, then let sleeping dogs lie... Much of that matter may be combustible but there'll still be a nasty load of abrasive matter there that would be best not entering the engine in any large volume. Maybe try something but take it gradually. |
Surely the mucky contents of the manifold and the rest of the induction system were intended by the manufacturer to pass through the engine as part of the normal combustion process. Where would any abrasive material come from?
Intended, yes, but still at detriment to the engine, and most significantly, only gradually. I don't see that it would be likely to cause issues to remove it slowy, but if measures are too "effective" and the dislodge it in lumps it wouldn't be appreciated. All that soot build up contains plenty of nasty stuff originating from the fuel, oil and perhaps even the engine itself. To an extent it's all the soot itself that's abrasive - harmless enough as hydrocarbons in the fuel but once separated it nucleates and into more damaging particles. ![]() Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
If you're prepared to remove parts I've read oven cleaner works well.
