Home > Technical (L322) > very loud under acceleration |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
Mine was noisy when accelerating, especially when cold, it was mostly engine or intake roar though, as it had a k&n filter on it, which makes it louder. Never noticed much exhaust though.
24th Jan 2016 8:22pm |
smighall Member Since: 15 Jan 2015 Location: West Sussex Posts: 68 |
Probably the viscous fan I would guess. Check it hasn't locked up. |
24th Jan 2016 8:26pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
Viscous fan is a good call, mine on the disco is a noisy as a noisy thing when it's cold. Eases off after a little while though. There is nothing that can't be fixed with a hammer😜😜
24th Jan 2016 9:38pm |
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 |
Hole in the turbo hose is quite common 2010 defender utility
24th Jan 2016 10:40pm |
ian Member Since: 24 Jan 2016 Location: chelmsford Posts: 22 |
hi, how do you check if the fan is locked up? the noise is quite loud under acceleration, but not there when cruising or just revving in neutral.. it sounds like a big performance exhaust but that all looks normal and in reasonable condition, with no obvious blow points.. |
26th Jan 2016 4:02pm |
Assuming i have located the correct hose (front left of engine, about half way down probably 2.5" in diameter, the pipe seems quite soft for an intercooler pipe. is it possible it is collapsing under acceleration, so causing the engine to strangle itself? |
26th Jan 2016 4:04pm |
unlikely to collapse itself as it is under positive pressure, when boost is applied. There is nothing that can't be fixed with a hammer😜😜
26th Jan 2016 5:03pm |
frikkadel Member Since: 09 Mar 2016 Location: joburg Posts: 56 |
If a viscous fan locks up, then would it not cool more than is required?
22nd Jul 2016 9:23am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
To check fan, get a rolled up newspaper and try to make confetti with it, start engine from cold and wait about 2 mins, then jab away, you should be able to stop the fan pretty easily if it's working, if you decorate yours and the neighbours drive then it's seized.... Pete
22nd Jul 2016 3:43pm |
