Home > Maintenance & Mods (L322) > -3 this morning........ |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
Think all you guys should fit a second battery in the boot as Dan_1984_Uk did.
19th Jan 2016 11:54am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
hee-hee, i have those days. i say to the missus, 'either get in the back, or sit in front, but put your feet on the battery!'
19th Jan 2016 12:15pm |
rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185 |
That second battery idea is cool.
19th Jan 2016 12:53pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
Mine did the same on Sunday morning but hadn't moved for 2 days so after a little assistance and praying she roared into action.... Is this where I put the car details and a bit about myself ?........ |
19th Jan 2016 1:37pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2641 |
I had to call the AA out in between Christmas & New Year. Wife had parked nose in so couldn't get a jump, hate these fecking things sometimes! |
19th Jan 2016 1:48pm |
Wife just called me. Car won't start again. If it's not the cold killing the battery it's the random battery drain.
19th Jan 2016 2:11pm |
betonklinker Member Since: 19 Nov 2015 Location: Amsterdam / Netherlands Posts: 68 |
I have the same problem.. The car is on the battery charger / dropper on the ramp to the night come at 0 degrees or less .... I 'm going to first replace the FSR since the blower sometimes hard and sometimes soft blows ... which I suspect as a first problem.
19th Jan 2016 2:40pm |
I had -6 |
19th Jan 2016 2:57pm |
There was is a car garage near were the Wife works and one of the lads saw her trying to jump it like I did this morning (pictures above)
19th Jan 2016 3:05pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Just to be helpful, how do you know you have a battery drain, have you tested for it?
19th Jan 2016 3:54pm |
Basically the non start problem started back in Nov 2015.
19th Jan 2016 6:46pm |
Have you considered the ignition switch may be intermittently faulty?
19th Jan 2016 6:55pm |
I know the ignition was changed by the previous owner as there was a receipt with all the paperwork but I haven't had that looked at.
19th Jan 2016 7:40pm |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
Might be worth spending 10 minutes checking the battery terminals and all earth straps to the engine from the body / chassis
19th Jan 2016 8:24pm |
