![]() | Home > Maintenance & Mods (L322) > Hill Descent Switch |
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 114 ![]() ![]() ![]() |
I'm told that the switch is only avalable as part of the whole panel. I'm missing the switch top on mine, but at least I do have the two prongs sticking up so I can still operate the switch.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 ![]() ![]() ![]() |
superglue?? |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
you can get special superglue for plastics. It normally has a marker pen with an activator in it as well as the normal glue. That's pretty strong. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1392 ![]() ![]() ![]() |
You could try drilling a small hole in to the two parts and adding a wire dowel to strengthen the join. Only Range Rovers since 1988 |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 ![]() ![]() ![]() |
Similar issue with mine although was SWMBO handbag that she insists on putting on top of cubby box, then voila, first braking and it flies down and takes switches out, both mine have gone and will go again. I have put a couple of screws into the bottom plastic bit and although ugly, work perfectly |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8679 ![]() ![]() ![]() |
would go with the 2 part superglue, or carpenters Mitre fix keep someone the desk at home will stick most stuff to most other stuff permanently There is nothing that can't be fixed with a hammer😜😜
Big Tings Member Since: 03 Apr 2015 Location: Vogue Posts: 22 ![]() ![]() |
Had one of mine break so managed to get a second hand part and change the switch over, these just click into place on the plastic struts. Also if you do manage to get a second hand switch if you turn it over you can undo the switch under the panel and swap that over to your panel. If yours needs a new sticker showing the different stages these are available on eBay that's if someone on here can supply those. Fiddly job but easily doable if you take your time and care when pushing on or pulling off the switches. |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 ![]() ![]() ![]() |
Thanks All
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
I had this on my previous car - our 5 year old (then) decided to jump through the gap and snap exactly the same
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 166 ![]() ![]() ![]() |
Don't ever touch my FFR |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16311 ![]() ![]() ![]() |
They used to sell a cheap version of the panel years ago. Don’t know if its still that way? Maybe ask Ducky Dan? |
