Home > Maintenance & Mods (L322) > Hill Descent Switch
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Hill Descent Switch
So ... my dear child thought he'd surprise me by jumping into the front seat whilst I was opening up the rear door to get him out.
Surprise me he did - he's managed to snap off the top of the Hill Descent Switch on the centre console - so all I have is a bit of rough plastic - can't get a grip on it either so can't use the function. Big Cry
Thankfully car is in normal mode so I can still drive it.
So what's the solution? Open up the centre console and replace said switch I assume? Is this available as a standalone part or am I looking at a breakers?
Over to the gurus ...
C African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #367042 14th Jan 2016 2:49pm
mike whiskey
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
I'm told that the switch is only avalable as part of the whole panel. I'm missing the switch top on mine, but at least I do have the two prongs sticking up so I can still operate the switch.
Should you be willing to sell the top of your broken switch to me I'd be happy to provide some small offset to the cost of the new panel.
MW Car history includes: LR Series 3, RR Classic x 4, LR 101, Discovery 1 and 2 and now FFRR.
Yes I'm a masochist....
Post #367043 14th Jan 2016 2:56pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
superglue??
Post #367049 14th Jan 2016 3:16pm
Zirconblue
you can get special superglue for plastics. It normally has a marker pen with an activator in it as well as the normal glue. That's pretty strong.
Post #367062 14th Jan 2016 4:26pm
CS
You could try drilling a small hole in to the two parts and adding a wire dowel to strengthen the join. Only Range Rovers since 1988
Post #367063 14th Jan 2016 4:28pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Similar issue with mine although was SWMBO handbag that she insists on putting on top of cubby box, then voila, first braking and it flies down and takes switches out, both mine have gone and will go again. I have put a couple of screws into the bottom plastic bit and although ugly, work perfectly Thumbs Up
Post #367088 14th Jan 2016 5:47pm
would go with the 2 part superglue, or carpenters Mitre fix keep someone the desk at home will stick most stuff to most other stuff permanently There is nothing that can't be fixed with a hammer😜😜
Post #367093 14th Jan 2016 6:30pm
Big Tings
2004 Range Rover Vogue Td6 Bonatti Grey
Had one of mine break so managed to get a second hand part and change the switch over, these just click into place on the plastic struts. Also if you do manage to get a second hand switch if you turn it over you can undo the switch under the panel and swap that over to your panel. If yours needs a new sticker showing the different stages these are available on eBay that's if someone on here can supply those. Fiddly job but easily doable if you take your time and care when pushing on or pulling off the switches.
Post #367104 14th Jan 2016 7:23pm
DeRanged Rover
Thanks All
Will try the glue fix but otherwise, off to the breakers it is!
Stats:
2006 TD6 Vogue SE
Post #367779 18th Jan 2016 3:02pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
I had this on my previous car - our 5 year old (then) decided to jump through the gap and snap exactly the same
only solution for me was a new panel.. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #367809 18th Jan 2016 4:33pm
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
Don't ever touch my FFR Twisted Evil
In this case I trade in the child for another one Whistle
Post #367823 18th Jan 2016 5:51pm
comports
Laughing I was tempted to write "only solution for me was a new child" Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #367826 18th Jan 2016 6:02pm
They used to sell a cheap version of the panel years ago. Don’t know if its still that way? Maybe ask Ducky Dan?
Post #367874 18th Jan 2016 10:06pm
