Home > Maintenance & Mods (L322) > Gap iid bluetooth
Page 1 of 4 1234>
Hairball
England 2006 Range Rover Vogue TDV8 Java Black
Gap iid bluetooth
Hi all got my iid bluetooth today paid my £25 to gap sent the 10 digit activation number etc anyone know when i will get my unlock code as i herd they dont work saturdays Big Cry
Post #367223 15th Jan 2016 4:28pm
Hairball
Whos the person on here to ask?
Post #367233 15th Jan 2016 5:58pm
CY
2002 Range Rover Vogue Td6 Epsom Green
You can get it immediately by activating on their website Thumbs Up 2002 Range Rover Td6 Vogue
Post #367249 15th Jan 2016 7:20pm
Hairball
When i filled the details on there website i got email saying its being processed ive been all through there website and it says after paying the money most people have to wait 2 hrs for code to unlock iid tool ive been waiting 5hrs now
Post #367253 15th Jan 2016 7:27pm
Hairball
I sent activation code to them i have no unlock code
Post #367254 15th Jan 2016 7:29pm
Weegie
Have you looked in your junk mail folder? They say that it sometimes happens depending on your system. John
GAP iiD BT
Post #367257 15th Jan 2016 7:46pm
Hairball
Yes no junk ,on there website when i log in it says processing as its done for last 5 and half hours
Post #367259 15th Jan 2016 7:49pm
Hairball
Just had email from patric telling me to send the activation code and they will do owner transfer i have done this 3 times now and replyed to his email with the same code Sad
Post #367261 15th Jan 2016 7:55pm
Hairball
Hi and help lol i got code off patrick all working fine checked through everything see what was on or off ie sat nav on go etc all was well i then went into phone itwas set to blutooth n nokia cradle i changed it to blutooth modual and clicked update or what ever it is and all hells broke loose all the dash n car shut down like it had no battery on it then seconds later all came back on but with every light and faults galor and car is dead not starting or turning over but im intouch with patrick at gap who is trying to sort it out its blowed my mind Big Cry
Post #367277 15th Jan 2016 10:57pm
Mikey
Change the settings back Whistle
Post #367279 15th Jan 2016 11:01pm
Hairball
It wont even work patrick running me through everything for hours
Post #367281 15th Jan 2016 11:25pm
Lost for Words
Unfortunately, you are now learning the ways of CCF editing the hard way. This is why a CCF setting should never be changed unless you know it needs to be. Why did you decide to change the setting? I think I'm right in saying it was correct beforehand. Question
Trust in GAP; they will get you sorted in the end, but please, please read the manual and be more wary in future. These tools are very powerful and need to be used with caution. Flashing ECUs carries some risk even for professionals. Thumbs Up
PS: The experience of the car shutting down and coming back to life with lights showing is perfectly normal when flashing ECUs. It does take some getting used to. Normally, the ignition needs to be cycled and the IID will clear the faults and all will be OK. Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #367314 16th Jan 2016 9:29am
Hairball
Hi yes i am a fool i did read the manual before hand but obviously did not understand it .all i was doing was trying to make my phone contacts show on touch screen on my last rrff bodsy came out and did for me so i had a look around on iid but could not find how to do it ,but i changed bluetooth with nokia cradel to bluetooth modual and updated it ,it then came up with no phone so i thought o well ill restore back to as it was ccf restore and bam all lights on dash all fault codes scrolling no starting or turning over and iid tool was not connecting to car, patrick has been more than helpfull and it now accepts iid tool and restores my ccf but still is the same after doing all this i think today he is going to restore with a factory rrff ccf so fingers crossed he can sort it out Bow down
Post #367317 16th Jan 2016 9:51am
Wise words... Bow down
Post #367319 16th Jan 2016 9:56am
Lost for Words
Hopefully that'll do the trick. Thumbs Up
To get what your after you need to look under "ECU Flash". Wink
NB: It's a long flash so back up power should be used - a standard charger is not suitable; you need a smooth supply mode, or alternatively, jump leads to another car with the engine running. Don't interrupt it or do anything that could cause any voltage fluctuations while flashing. In short, good, stable voltage is key to successful flashing. Thumbs Up Visiting from DISCO3.CO.UK
Post #367327 16th Jan 2016 10:06am
Page 1 of 4 1234>
