Home > In Car Electronics (L322) > Venture Cam Repair.
Page 3 of 4 <1234>
dan_uk_1984
Top post, just followed your guide to repair mine.
Thanks!
Post #341491 9th Aug 2015 5:31pm
Eirik34
Norway
I've replaced the Venture cam as well now - easy fix, thanks to Dave699 Smile .
Great forum, this one Thumbs Up
Post #355403 4th Nov 2015 11:43pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Hi,
Found these as alternative replacement batteries,
http://www.vapextech.co.uk/7-2v-battery-pa...extech-rx/
For the electrically minded is there a good reason not to ugrade to 950 mAh from the 800 mAh, would it overload the recharging circuitry?
£8.44 inc delivery!
Just double checked the size......no good, please disregard Evil or Very Mad Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #367019 14th Jan 2016 12:43pm
forever
did you know which fitting is needed?
Post #367024 14th Jan 2016 1:07pm
3528cc
Choice was Futaba 4 pin or JST 2 pin
either way there is the harness from the originals to re use Regards
Royston
1999 Rover BRM
Post #367026 14th Jan 2016 1:12pm
navrac
United Kingdom 2006 Range Rover Vogue Td6 Java Black
these look pretty good
http://www.ebay.co.uk/itm/1-2V-NiMH-Single...8L5bQrfs5g
type G £5.95 for 6 inc delivery with the tags on to simplify the construction and hopefully not require cutting down the splines.
or if you don't mind spending a bit more £18.99 + £5.99 delivery then this is pack that just needs the two ends soldered.
http://www.conrad-electronic.co.uk/ce/en/p...m?ref=list
Post #375641 3rd Mar 2016 11:12pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Hi all. About to fix my cam and on a certain site you can get 7.2V 1300Ah pack for a remote control car , etc for 5 stg
Any reason this could not be used with correct connection fitted ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #378708 21st Mar 2016 5:32pm
navrac
mainly because most of the battery packs with that capacity are based on AA cells rather than AAA cells so won't fit. you may get lucky though.
Also if you are talking about the 'zippy' one on that site - it is actually two 3.6V lithium cells in series and would make quite a good job of setting fire to the car or blowing a passengers knee off.
Basically you can't charge lithium batteries without a special charger - otherwise they keep drawing current and overheat and then either catch fire or explode. I had to buy the wife a new freezer after I did some experiments on charging them. I was using the right charger but was experimenting with gently charging them at low temperatures. They don't like that much either!
Post #378719 21st Mar 2016 6:20pm
dolph34
Thank you and I'm very glad I asked 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #378764 21st Mar 2016 8:28pm
dolph34
Cam repaired. Thank you. Showed kids , played with it for about 10 mins and that's Proberbly the last time it will be used Very Happy 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #381330 8th Apr 2016 7:11pm
philcorsa
France 2008 Range Rover Vogue TDV8 Buckingham Blue
Hi everybody,
need some help
i want to fit a venture cam into my RR vogue TDV8, i have the docking station and the venture cam, but i need to know how to plug the dock, i search everywhere on forum and manuel but nothing, any help welcome !!
Post #381879 12th Apr 2016 2:42pm
Realist
Wales
Mines in bits on my desk and while taking it apart the plug that connects the PCB from the battery just disintegrated into pieces.
Anyone know where I can get another 5 pin from? Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #382964 20th Apr 2016 11:05am
Dieterf
South Africa 2007 Range Rover Supercharged 4.2 SC V8 Java Black
YUP.My plug also disintegrated Big Cry
Anyone have an idea what they are called, so i can try and source.
TX
Post #383541 24th Apr 2016 4:32pm
steeplejack
Wales
My dock doesn't stay in place. I used a bit of paper to hold it in and it has charged up and is working fine. Batteries are probably still holding a charge because it hasn't been charged much, although not sure how much charge they will hold as only played with it for a few minutes.
Post #383542 24th Apr 2016 4:40pm
Realist
Wales
I know they are called JST but their are loads of sizes.
TX
Post #383594 24th Apr 2016 9:01pm
Page 3 of 4 <1234>
