Home > Technical (L322) > Dead Battery |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7923 |
What are the usual tricks that you've tried ? |
13th Jan 2016 5:04pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
if you take the under tray off you should be able to connect a positive jump lead to the back of the alternator and the negative anywhere on the engine.
13th Jan 2016 5:06pm |
Cobbler Member Since: 22 Jun 2015 Location: London Posts: 4 |
Hi Zirconblue, I thought of that and was told it wouldn't work but ill give it a try!
13th Jan 2016 5:23pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8503 |
do you have a tow bar?
13th Jan 2016 5:33pm |
I don't see why it wouldn't, it'd be the same as putting it straight to the battery, doing the same to the starter should have the same effect. If you have a 13pin or twin 7 pin towing electrics that's another point you can feed power to the car. |
13th Jan 2016 5:34pm |
Front fog light Haven't heard that one before - it wouldn't have a permanent live connection there would it ?
13th Jan 2016 5:44pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3971 |
You should be able to connect onto the large cable connection on the starter on a TD6 without dismantling anything.
13th Jan 2016 6:08pm |
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 |
I also read about using the front fog light ,but on every occasion they refer to using the near side ? 2007 tdv8 se ,stornaway grey |
13th Jan 2016 7:12pm |
just had a look at the wiring diagram, i can't see how feeding power to either fog lamp would give a permanent live. |
13th Jan 2016 7:25pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2575 |
apparently there is a way in through the number plate light and pop the tailgate, maybe do a search? although I am sure it hasnt been open posted |
13th Jan 2016 7:42pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
My recollection of the 2004 car was that it had a physical key that could unlock the driver door - is that not right?
13th Jan 2016 8:51pm |
You're right it does, but i have an idea if it's superlocked (aka dead locked, double locked) the key doesn't work. |
13th Jan 2016 8:54pm |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 |
As said above, have you tried the key, just been reading my manual for my 2008, it states that superlocking occurs automatically with remote and key locking. No mention key lock being isolated
13th Jan 2016 9:22pm |
