Home > Technical (L322) > transmission oil/filter change |
Declan303 Member Since: 08 Dec 2015 Location: Meath Posts: 151 |
Guys is this http://www.paddockspares.com/auto-transmission-service-kit-1.html the correct kit for a 03 Vogue transmission oil/filter change. Probably won't buy Britpart but just want to confirm correct parts plus oil of course.
11th Jan 2016 11:57pm |
Nobody any idea no! |
13th Jan 2016 3:05pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
what do paddocks say? ... - .- -.
13th Jan 2016 3:13pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
Yes that does appear to be correct. For the early v8. And at a cheap price too. Just make sure you are using the correct lt71141 fluid, and not equivilent. It's about £11 a litre, and only badged as Mobil. Get it online. P.s. It's honey/yellow coloured. |
13th Jan 2016 4:28pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6721 |
I bought mine from forum sponsors AF Advanced Factors. Got everything I needed by searching through to my model type on their web site. Got - 2017 SDV8 Autobiography in Loire Blue
13th Jan 2016 4:38pm |
Cheers guys thanks for replies.
13th Jan 2016 4:47pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
It's also badged as Esso too, Esso is the same company as Mobil. |
13th Jan 2016 5:09pm |
acrr1 Member Since: 30 Aug 2015 Location: Thirsk Posts: 24 |
The auto box is one area where it doesn't pay to use pattern parts - try Dan at Duckworths, he was very helpful when I did mine. |
13th Jan 2016 5:20pm |
normally i'd agree but the filter is a VERY basic item, it's nothing special. |
13th Jan 2016 5:35pm |
I had a quick look underneath today and could not see the filler plug on the gearbox. Any idea where its located, left, right, front back etc. There is a plug just to the front of the sump pan but somehow I don't think that is it.
21st Jan 2016 7:42pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
It’s on the right-hand side of the casing near the back of the transmission
21st Jan 2016 9:12pm |
Thanks Phil |
21st Jan 2016 9:23pm |
Might be a daft question but anyway here goes. When I was changing the gearbox oil and filter the other day, I was wondering if there is any way to get extra oil out rather than just what drains from the sump. Would giving it a dig of the starter push more back into the sump or would that be a mad thing to do and possibly cause damage.
4th Feb 2016 7:24pm |
The torque converter and valve body do retain a lot of fluid. Personally I’m a fan of just doing a drain and refill as it refreshes only just over half of the fluid and so reduces the risk of ‘detergent shock’ (i.e. the fresh fluid cleaning out all the gunk that has settled in the nooks and crannies) and also upsetting the controller’s adaptions through changing the clutch-pack friction characteristics.
5th Feb 2016 11:52am |
