![]() | Home > Maintenance & Mods (L322) > Power Pack/Jump Pack. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
Call me a cynic - but that I would like to see - I could accept that it would work from the car being slightly below being able to fire the car, but 'completely flat' takes some serious juice and even most jump leads aren't up to the job. |
^+1 |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I'd be inclined to agree, but in the video, it shows the guy starting a V6 toyota multiple times, with the main vehicle battery disconnected.
And if the jump pack has been left in the freezing car that may well affect it's efficacy. And a cold diesel whether it uses it's glow plugs or not will take a lot of effort to fire when cold, either the plugs will take a load of juice from the battery, or it'll have to be cranked repeatedly to get the compression temperature up enough to fire it. It has to be better than those things that do it though the cigar lighter on the other hand. ![]() |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
When my 4.4 TDV8 battery was completely flat the pack carried by the LRA technician didn't even prime the ignition, it needed a few minutes on the leads from his D4 before it responded. The second time it happened the LRA technician had a van, VW I think, and that started it sooner, he said the output from the van was higher than that of the D4, but the fact that the battery could not be revived on the first occasion might have been a factor too. Apparently the higher output was a reason for LRA moving to the vans, I am afraid I had suspected D4 reliability |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
I had a jump off a small starter pack in the isle of wight ferry Q a few years back, started the 3.6 from a little bit flat (had been sitting listening to the radio for a while) was only a cheap unit the chap had, and worked, but only just...... had to sit in the car with it running on the ferry as it pulled out of port to charge the battery.... There is nothing that can't be fixed with a hammer😜😜
Duracell777 Member Since: 07 Sep 2015 Location: Warwickshire Posts: 128 ![]() ![]() ![]() |
Or this...
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
It looks the same as this one I have saved but look at the feedback numbers!
rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185 ![]() ![]() ![]() |
4.8 out of 5 and 181 reviews!
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Battery jumping aside, those packs are also ideal for keeping about ones person in case of ones phone / iPad / laptop running out of charge.
cirks Member Since: 15 Sep 2014 Location: Dark Side Of The Moon Posts: 55 ![]() ![]() |
The mini/micro booster packs certainly looking interesting and much better/easier to keep in the car than some of the big packs (assuming the reviews are accurate!).
sodalis Member Since: 18 May 2014 Location: Flintshire Posts: 26 ![]() ![]() ![]() |
I have one of these small power packs with 300A start current, 600A (3s) peak current and although it seems to start small petrol-engined cars with no problem, I've never been able to get it to make my FF even cough:(
Has the pack come yet? is it worth the money, does it do what it says on the box? cheers |
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 ![]() ![]() ![]() |
[quote="ije44"]Just to add to the mix, I bought one of these
would be interesting to know whether the ebay one and amazon are actually the same item or Chinese copies of each other. The Amazon one is branded, the ebay one isn't. Ebay one from seller based in China (despite the location being 'Derby') whereas Amazon supplier is London based. The two machines also have different specs 13600 vs 16800 too. THere are so many of these packs available now, it would be really good to know which brand and which supplier are the best ones! |
