Home > Technical (L322) > Turbo Waste Gate |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 |
Just a quick bump seeing as it was put on new years eve, in the hope someone might know 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts |
2nd Jan 2016 7:50am |
smighall Member Since: 15 Jan 2015 Location: West Sussex Posts: 68 |
Boost pressure sensor or MAF? |
2nd Jan 2016 8:18am |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 610 |
Silly question but you have checked the hoses underneath the protective sheathing? Quite a coon area for it to split I hear (that's where I had mine split). Ed |
2nd Jan 2016 8:21am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1764 |
If it was a split hose, I would expect it to be smokey at all times, and for the ESF warning to much more frequent
2nd Jan 2016 8:56am |
I checked under the webbing sadly no split. As mikey says I am fairly certain it's the actuator which is gummed and sticking the waste gate open.
2nd Jan 2016 9:27am |
You are correct, WD40 to free the arm off, something else to keep it lubricated
2nd Jan 2016 10:08am |
Thanks
2nd Jan 2016 12:39pm |
Ok update for those who find themselves with a sticky actuator / waste gate.
6th Jan 2016 1:05pm |
Done exactly this in a D3 today, after the owner was quoted £4000 to replace his (blanked) EGR valves, as they need elimated first, then most likely the turbo on top of that
6th Jan 2016 7:45pm |
Yeah I preferred doing the D3 you just remove the battery box and you get a birds eye view of the turbo actuator. The Rangie is more keyhole surgery
7th Jan 2016 2:06pm |
That's not a bad idea
7th Jan 2016 9:20pm |
Ouch not much room to swing a cat nevermind fit a turbo 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts |
7th Jan 2016 11:28pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Had P132E error appear at the weekend and have just spent 2 hours under my RR trying to get at the LH actuator, without much success.
22nd Feb 2016 7:31pm |
I removed the bottom plastic engine cover then used a coathanger ....no wait ... it was a bucket handle .. same thing just stiffer. Made a hook in the end then lying under the car looking from the rear above the diff with good directional led torch I hooked the bottom of the arm. The bit you can see is the bottom where it connects to the turbo. I had to pull quite hard first time and it released with a clunk it was stiff. It the arm the actuator attaches to looks level then it's stuck up, if it looks like its pointing down at 45 degrees then it's stuck down.
23rd Feb 2016 9:48am |
