Home > Maintenance & Mods (L322) > Bit of a groan (4.4 TDV8)?
pld118
Just noticed a slight (hard to describe) groan/whoo/ secondary lightly tinny metallic sounding noise when the car accelerates normally from a standstill, more so if going up an incline perhaps. The faintest of noise but something that has come on recently.
Ive recently changed the front Diff Oil and also had both front wheels off to clean them.
Any ideas welcomed please?
Thanks.
Post #363006 20th Dec 2015 5:56am
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Hi pld118
just read the above -
any chance you can grab a sound file from your Iphone from inside the FFRR and put a quick upload on YouTube and post a link here so we can all hear it - it will help us identify what this might be.
Just out of Interest - both our FF have got K&N air filters fitted ( 4.4 TDV8 lumps ) you can clearly hear the Whoosh and V8 growl when the car accelerates - have you just replaced the air filters lately ?
another point - have you checked all your Wheel nuts are tight ( 140Nm ) - worth a check Thumbs Up
Post #363025 20th Dec 2015 9:50am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Interesting.........
http://www.fullfatrr.com/forum/topic1981.html
Post #363030 20th Dec 2015 11:00am
pld118
Thanks for replies.
No recent filter changes, nuts tight and I'd read that whine thread but felt it took me no further.
Not sure if a sound recording would pick up as so low a noise but will try Thumbs Up
Post #363044 20th Dec 2015 11:58am
Was the wife in it at the time Ryan Whistle Whistle Whistle
Post #363049 20th Dec 2015 12:41pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Craig,
Would that explain the Whine or.....the 'tight nuts' Whistle Whistle
Post #363055 20th Dec 2015 1:27pm
Could it be something come a adrift somewhere Ryan? Mine makes a few odd noises on occasion. None of which have gotten worse or better. And are intermittent.
What sort of area is your noise from?
Heavy or light acceleration?
Every time or occasionally?
I'm wondering if my noises are the same ones. Not sure though, I get like a little warble as it changes up from 2 - 3 and I back off, like a triple tone type noise three warbley quick hoots. Personally think it may be a boost valve releasing some pressure, it's been there since I've had it. And I can't make it do it! Just does it when it feels like it There is nothing that can't be fixed with a hammer😜😜
Post #363105 20th Dec 2015 4:45pm
pld118
Mark,
1. Could it be something come a adrift somewhere ('hoot')?
Possibly, you mention 'hoot', I've described a whoo type noise.
2. What sort of area is your noise from?
Front driver's side quarter in the area around the front wheel/ in front of the pedals/ around the engine bay.
3. Heavy or light acceleration?
Light
4. Every time or occasionally?
Every time I've driven it in the last few weeks but I've only been driving it a couple of times a week and briefly at that. Someone else drives it every day but hasn't noticed anything. I suspect the radio inevitably drowns things out Rolling Eyes
Could it be gearbox related???
Post #363420 22nd Dec 2015 4:07am
EmiratesA380
Ryan
from what I am reading and hearing it sounds like you have a
nut lose on the Front Disc Stone protector plate behind the disc - this will make a alloy reverberating sound
they are made of very light tinny metal plate that if you flick it will make a twang sound ?
Check the nuts are secure or is anything out of alignment where the discs runs.
Out of interest:
Is the Disc mounted flush on the carrier plate ( have you taken the disc / wheel off lately ) ? - Brake pads seated in correctly ?
Post #363445 22nd Dec 2015 9:48am
pld118
Actually, Emirates, the protector was a thought for the reasons you mention and describe.
I've had the wheel off to clean it a few weeks ago too. Will check all thoroughly over the coming days and report back.
Incidentally, drove it this morning from cold and was tootling around locally and not a peep!
Post #363464 22nd Dec 2015 12:16pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Have something similar, almost like someone's stuck one of those whale sounds CDs on. Doesn't happen very often.
Post #363470 22nd Dec 2015 12:38pm
yep thats the puppy, front drivers side wheel well whale noise.
sounds like a common noise then.
I will check the brake backplate on mine too to see if its loose, as it seems to mostly happen when turning too as far as i can tell. Rolling Eyes There is nothing that can't be fixed with a hammer😜😜
Post #363499 22nd Dec 2015 4:26pm
PaulB
Any update on this please guys?
Post #374926 29th Feb 2016 5:36pm
not got any worse.....
not noticed it happening particularly either recently..... Rolling Eyes
but i did turn the radio up Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #374931 29th Feb 2016 5:50pm
PaulB
The sound of a whale describes what i have been getting since i purchased my 3.6 last July.
Happens under load @ around 2k rpm.
No noise when at stand still.
It does annoy me but sounds like quite a few cars have this.
Cheers
Post #374936 29th Feb 2016 6:11pm
