![]() | Home > Technical (L322) > More FBH Info |
You guys with the oil burners might find the info on this Rover/MG page interesting as they have the same fuel burning heater fitted to their diesels...
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Cheers for that, just printed the document off |
Thanks Dan - nice find! I found the Webasto SW a while ago, but no instructions. And I've not found the time to play with it yet. May have to now, tho, as it's getting colder and I def want the pre-heat to work this year. I actually thought that the activation of the pre-heater would be within the HEVAC (so I've been trying to get INPA to work), but on second thought this makes more sense. The HEVAC just needs to know to turn on the blower when the appropriate signal comes from the FBH. Fingers crossed.
I'll try running the SW on the ibus this eve - failing that, do you know which wire the Kbus is and where it can be found?
K is RW (red w/ white stripe) found on all sorts of ECUs - unfortunately none that spring to mind w/o opening a panel or removing something: the BCU under the RH Seat, the EAS ECU (next to glovebox), Wiper control module, LCM, etc.
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
A wiki is planned - watch this space |
Couldn't seem to communicate with the FBH this eve over the ibus/kbus. Will give it another go tomorrow ever, but it started raining and was freeeezing. I'll be glad for the fbh tomorrow morn! |
Anyone else got the resler interface AND a pre-heater? (diesel?)
Yep - both. But I won't be able to try before the weekend.
Allrite Dave, sorry I couldnt get the model number/type off mine for you...
dan, i will text you his number, have a word with him, the firm ware upgrade may be possible to earlier units
Hey Dave - are you talking about Art Tevs? Has he done a second monitor (couldn't find one on his site). His first monitor was just a generic 7" touch screen monitor (on which he broke the digitizer during re-assy - so no touch screen now). The signal from the oem nav to the monitor uses a RGsB (sync on green) to VGA convertor - they are relatively easy to find.
Nice bit of pre-heating in the morning:
paul_h_8 Member Since: 09 Jun 2010 Location: North East - England Posts: 256 ![]() ![]() |
Just read the whole of above and still don't understand what i need to achieve what Dan's done above.
