Home > Technical (L322) > More FBH Info |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
To do what Dan's done, you need to sell your TD6, buy a 4.4 and make sure it has had the FBH pre-heater installed by LR. (and the get a LPG conversion)
16th Nov 2010 5:35pm |
Do you have the wiring there already to plug the reciever into? There should be a loose plug behind the fuse board in the right of the boot, its only two bolts to see... |
16th Nov 2010 5:45pm |
It won't work w/o the pre-heat function being activated. I have the wiring and I've tried. RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
16th Nov 2010 9:51pm |
Steve - doesnt the control module override the cars settings? It sends a signal to the fbh unit to run for x duration? To manually get the fbh to run you just ground the 3rd wire or supply 12v+ to it (depending on exactly which we have) - to this end it is very easy to install a webasto 7 day timer if you dont have the MID. The Rover 75 has the timer module in the cubby box so this could be an option for some. Complete systems are sold on ebay to get a fbh to work as a pre-heater... This looks plug n play: http://cgi.ebay.co.uk/WEBASTO-THERMO-TOP-H...2eb12efab3 but may but interface with vehicle systems... |
16th Nov 2010 10:01pm |
Tried the 12v jumper (and gnd - but ours are most likely 12v) last winter after the remote receiver seemed to have no effect. No dice. I would have left the silly activation probs for someone else to solve...
17th Nov 2010 6:51am |
Often with iBus attatched devices there mere presence enables them. Sometimes takes an ignition cycle to pick thinsg up, sometimes a short time delay and sometimes a power disconnect.
17th Nov 2010 9:01am |
Hi Dan,
17th Nov 2010 1:50pm |
Wow Steve, that's certainly a lot to think about.
17th Nov 2010 2:12pm |
It really would be easier if we were all in the same corner of the world. I do get over your way every now and again. A couple of pints ought to be planned in.
17th Nov 2010 3:11pm |
Interesting, as that seems to contradict the manual. It says the remote heat "pre-heats the vehicle" which to me means interior too. Also if the valve blocks off the heater matrix why do the interior fans come on and blow hot air?? One thing I read on the Mg forums was that on the Freelander the unit waits till it gets up to temp and then switches the interior fans on so it concentrates on heating the block first. But this is a little here-say. Dan |
17th Nov 2010 3:39pm |
Actually, the way I understood it is the other way around; the heater matrix gets all the FBH's heat to make sure that the cabin is warm. The recirculation pump always switches on with the FBH to keep the unit from overheating, but the blower only comes on when a threshold temp is reached.
17th Nov 2010 3:54pm |
The block is definately heating, else the thermostant wouldnt rise? Hmmmmm |
17th Nov 2010 4:02pm |
That's why I was wondering if the hot water in the heater matrix surging into the cooling system when the motor is started suffices to make the guage rise? Or did you see the guage rise with just the ignition on - no motor running yet?
17th Nov 2010 4:37pm |
Nope, gauge shoots up as soon as ign on. Also if heater was just doing the cabin i would expect it to be warmer than it is... |
17th Nov 2010 6:03pm |
