Home > Technical (L322) > More FBH Info |
You guys with the oil burners might find the info on this Rover/MG page interesting as they have the same fuel burning heater fitted to their diesels...
7th Nov 2010 10:11pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Cheers for that, just printed the document off |
7th Nov 2010 10:24pm |
Thanks Dan - nice find! I found the Webasto SW a while ago, but no instructions. And I've not found the time to play with it yet. May have to now, tho, as it's getting colder and I def want the pre-heat to work this year. I actually thought that the activation of the pre-heater would be within the HEVAC (so I've been trying to get INPA to work), but on second thought this makes more sense. The HEVAC just needs to know to turn on the blower when the appropriate signal comes from the FBH. Fingers crossed.
8th Nov 2010 12:14pm |
I'll try running the SW on the ibus this eve - failing that, do you know which wire the Kbus is and where it can be found?
8th Nov 2010 12:35pm |
K is RW (red w/ white stripe) found on all sorts of ECUs - unfortunately none that spring to mind w/o opening a panel or removing something: the BCU under the RH Seat, the EAS ECU (next to glovebox), Wiper control module, LCM, etc.
8th Nov 2010 3:00pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 |
A wiki is planned - watch this space |
8th Nov 2010 3:03pm |
Couldn't seem to communicate with the FBH this eve over the ibus/kbus. Will give it another go tomorrow ever, but it started raining and was freeeezing. I'll be glad for the fbh tomorrow morn! |
8th Nov 2010 11:30pm |
Anyone else got the resler interface AND a pre-heater? (diesel?)
10th Nov 2010 8:45pm |
Yep - both. But I won't be able to try before the weekend.
10th Nov 2010 9:05pm |
Allrite Dave, sorry I couldnt get the model number/type off mine for you...
10th Nov 2010 9:47pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
dan, i will text you his number, have a word with him, the firm ware upgrade may be possible to earlier units
10th Nov 2010 10:08pm |
Hey Dave - are you talking about Art Tevs? Has he done a second monitor (couldn't find one on his site). His first monitor was just a generic 7" touch screen monitor (on which he broke the digitizer during re-assy - so no touch screen now). The signal from the oem nav to the monitor uses a RGsB (sync on green) to VGA convertor - they are relatively easy to find.
11th Nov 2010 12:37pm |
Nice bit of pre-heating in the morning:
16th Nov 2010 9:59am |
paul_h_8 Member Since: 09 Jun 2010 Location: North East - England Posts: 256 |
Just read the whole of above and still don't understand what i need to achieve what Dan's done above.
16th Nov 2010 10:16am |
