Home > Maintenance & Mods (L405) > Alloy wheel damage |
Many outfits will repair them. If you want a localised repair, they can do it 'at your door'. If you want the tyre off and the entire wheel refurb'd, they will do single wheels that you can 'post' or leave with them, in either case if you have a spare.
20th Dec 2015 4:00pm |
dealmaker Member Since: 08 Dec 2015 Location: Northumberland Posts: 13 |
They will have to remove some metal to repair that properly - so likely you can only get these rims repaired at most twice? |
20th Dec 2015 7:58pm |
EdJ Member Since: 30 Jan 2015 Location: London Posts: 329 |
Thanks for the replies - I had in my head that these diamond cut alloys were impossible to repair, so good to hear that that isn't the case.
20th Dec 2015 8:28pm |
JasM Member Since: 08 May 2015 Location: Lanarkshire Posts: 220 |
Yes those are diamond cut and yes it can be repaired. However the only problem is getting an even colour match of the inner spokes to match the colour of the other undamaged wheels.
20th Dec 2015 9:05pm |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
I've got exactly the same wheels and had them refurbished. Not any wheel refurber can repair these diamond turned wheels, only those who are specifically equipped to repair diamond turned wheels can. To match the colour perfectly you could send your spare wheel along with the one to be repaired so they can match the colour exactly. It is not hugely expensive, I had them done in France so the price I paid won't be of much help but be prepared to pay more than you would for a non diamond turned wheel. |
20th Dec 2015 10:39pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7892 |
I did something similar to one of my summer wheels - they are currently in my shed - so if you find somewhere good, then let me know |
20th Dec 2015 11:42pm |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 |
I too did something similar this week, but the tyre has a massive lump out of it too. Even bigger problem is that the black pack wheels have two colours and the first place I asked just said it was in effect double the refurbishment cost as they would need to mask, paint and rebake!
21st Dec 2015 12:20am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16227 |
A good repairer will weld that before they grind it back to its original shape... Then refurbish/refinish it... Have seen these refurbed many times over... |
21st Dec 2015 1:47am |
pjb Member Since: 15 Feb 2010 Location: Sunny Oxon Posts: 244 |
I have the same wheels & did the same on a local toll bridge when squeezed by a lorry
21st Dec 2015 10:05am |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1233 |
This might be a stupid reply (I'm not sure if the spare wheel is a space saver type on the L405), but why not just use the damaged wheel as the spare? |
21st Dec 2015 10:51am |
Not a stupid question, but you need to specify a full size spare (I have) and pay for it. So for some it is a space saver. Then there is the conundrum, do I put the immaculate spare on the car so it looks good but risk damaging it and having three half worn tyres and a new one?
21st Dec 2015 11:38am |
Surely that conundrum is standard practise with running 22” wheels Nick... Thats why most opt for 20" or 21” etc etc etc Life was much easier with the 322 |
21st Dec 2015 12:12pm |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4989 |
EdJ you are not alone any more - just dented one of my wheels All my spelling errorz are belong to me!
21st Dec 2015 12:46pm |
Craig, you will recall that inspected my first car with 20s but the SC was secondhand and came with the black pack and the obligatory 22s, which of course I need for the 155mph top speed on a regular basis
21st Dec 2015 1:07pm |
