Home > Maintenance & Mods (L322) > Lowering my RR? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Nope, not without removing all the air from the suspension. Puppy/Dog ramps are the way to go, or a step?
12th Dec 2015 3:15pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
you can use the iidtool to reduce the height, but it will be on all the modes not just access... ... - .- -.
12th Dec 2015 3:59pm |
Harrup Member Since: 01 Jan 2013 Location: Devon Posts: 25 |
Ah, bummer. Faffing with the ramp must continue.... My interior is all black, sorry |
12th Dec 2015 6:38pm |
What a pity - wish RR would come up with a "large/heavy/old dog" access solution. If our car parking spaces wouldn't be so piddly in size, getting out the ramp in town wouldn't be that much of an issue. Alas, they are and it is. Since I love the dog more than the car looks like my RR days are over. Beastly. |
12th Dec 2015 6:48pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
Or buy an L405
12th Dec 2015 6:53pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2470 |
I produce a plug-kit that will lower and raise MY07 and later L322s and some other vehicles using a driver-operated switch to signal a module that modifies height sensor signals. It can lower by 20 mm or 50 mm and 50 mm puts my MY12 on the bump-stops when used in conjunction with access height. However is 50 mm lower enough? I still have to help my wife's St Bernards in and out. |
12th Dec 2015 7:59pm |
Odd isn't it, more of a problem for the bigger dogs than the smaller ones. I guess a Jack Russell simply "boings" up into the back of an L322 like Tigger .
13th Dec 2015 10:19am |
You also don't mind lifting a smaller dog |
13th Dec 2015 12:27pm |
Snort. Why, of course! Why not buy the large puppy dog a spanking new RR. Must fall under "diligent owner" costs...grin. Still, my car is due a service anyhow so I shall sniff around the L405 and check out the boot access height. I actually can't believe that I am seriously contemplating buying my large breed pup a suitable RR. Yet, here I am.... |
13th Dec 2015 12:46pm |
Hmmm, 50 mm equates to roughly 1.5 " - is that right? Likely not enough but I shall bear it in mind. Thanks for letting me know. Out of interest - how much is the kit and fitting cost? |
13th Dec 2015 12:51pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
50mm is roughly 2 inches. |
13th Dec 2015 1:18pm |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 |
If lowering just the rear onto the bumps tops will give you a low enough height it can be done quite easily .
13th Dec 2015 4:57pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
You'll end up with a "Suspension Inactive" fault, and it will do a lockout
13th Dec 2015 5:20pm |
It works just fine on mine ..... |
13th Dec 2015 5:58pm |
