Home > Maintenance & Mods (L322) > Lowering my RR?
Harrup
2007 Range Rover Supercharged 4.2 SC V8 Rimini Red
Lowering my RR?
Hope I'm posting this in the right section. If not, would a kind mod please move it to the correct place? TIA.
I am wondering...hoping, actually...whether there is some way in which my L 322 could be lowered further than the access height? The problem in essence is my young Bernese. Yes, it is doable via utilising doggy ramps but, especially in town with narrow car parking spaces, faffing around with the ramp is tedious if not impossible.
All my previous Bernese jumped in and out of my previous P 38 without problem. But this model is not merely a couple of inches higher but the tail gate is not folding down as low as my P 38 or my Classic RR.
Is there ANY way of reducing the access height? Or, alternatively ( as per my husband's suggestion ) any way how I could lower the back only with the front suspension staying up?
MTIA!
Post #361845 12th Dec 2015 2:47pm
Nope, not without removing all the air from the suspension. Puppy/Dog ramps are the way to go, or a step?
However, if this makes the car not fit for purpose you have just the model I have been looking for, for over 18 months!, as long as you have a sand or ivory interior Smile .
Post #361854 12th Dec 2015 3:15pm
you can use the iidtool to reduce the height, but it will be on all the modes not just access... ... - .- -.
Post #361866 12th Dec 2015 3:59pm
Harrup
Ah, bummer. Faffing with the ramp must continue....
My interior is all black, sorry Smile
Post #361901 12th Dec 2015 6:38pm
Harrup
What a pity - wish RR would come up with a "large/heavy/old dog" access solution. If our car parking spaces wouldn't be so piddly in size, getting out the ramp in town wouldn't be that much of an issue. Alas, they are and it is.
Since I love the dog more than the car looks like my RR days are over. Beastly.
Post #361903 12th Dec 2015 6:48pm
Or buy an L405 Whistle
Mine will drop several levels and you can lower it from the remote like this Thumbs Up
Still might not be low enough though......
Post #361904 12th Dec 2015 6:53pm
GraemeS
I produce a plug-kit that will lower and raise MY07 and later L322s and some other vehicles using a driver-operated switch to signal a module that modifies height sensor signals. It can lower by 20 mm or 50 mm and 50 mm puts my MY12 on the bump-stops when used in conjunction with access height. However is 50 mm lower enough? I still have to help my wife's St Bernards in and out.
Post #361913 12th Dec 2015 7:59pm
Odd isn't it, more of a problem for the bigger dogs than the smaller ones. I guess a Jack Russell simply "boings" up into the back of an L322 like Tigger Very Happy .
Post #362000 13th Dec 2015 10:19am
You also don't mind lifting a smaller dog Whistle
Post #362036 13th Dec 2015 12:27pm
Harrup
Snort. Why, of course! Why not buy the large puppy dog a spanking new RR. Must fall under "diligent owner" costs...grin.
Still, my car is due a service anyhow so I shall sniff around the L405 and check out the boot access height.
I actually can't believe that I am seriously contemplating buying my large breed pup a suitable RR. Yet, here I am....
Post #362043 13th Dec 2015 12:46pm
Harrup
Hmmm, 50 mm equates to roughly 1.5 " - is that right?
Likely not enough but I shall bear it in mind. Thanks for letting me know. Out of interest - how much is the kit and fitting cost?
Post #362044 13th Dec 2015 12:51pm
Zirconblue
50mm is roughly 2 inches.
Post #362049 13th Dec 2015 1:18pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
If lowering just the rear onto the bumps tops will give you a low enough height it can be done quite easily .
You will need to route the tubing to the rear bags to a suitable place such as into the little cubby on the left in the rear , then fit 2 of these vented valves
http://www.swagelok.com/en/catalog/Product/Detail?part=SS-42GVS4
Closing the valves will automatically drain the 2 rear bags , and you'll simply open them to fill back with air to raise the rear .
Post #362079 13th Dec 2015 4:57pm
miggit
You'll end up with a "Suspension Inactive" fault, and it will do a lockout Shocked
There maybe some mileage in 'T' ing in to the air lines for the rear and using the valves to dump all the air from the bags, but the engine would have to be off and the key out! If your lucky, that way it will just think there is a leak and fill the Air Bags back up on starting, without the fault..... But I am only guessing now, haven't really tried to get the car on the bump stops..... most of us spend all our time trying to stop that from happening Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #362084 13th Dec 2015 5:20pm
Ian c2
It works just fine on mine .....
Post #362087 13th Dec 2015 5:58pm
