![]() | Home > Maintenance & Mods (L322) > Hit standing water fast & hard |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
plastic wheel arch liner rubbing on a tyre i expect.
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
My money is on the wheel arch liner - possibly grill section at the front of it?
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
Its definitely metal on metal rattle and scrapping ? Does the wheel arch lining have any metal ? 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
All plastic i think. Could be a water shield on one of the brake discs.
Exhaust heat shield |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3217 ![]() ![]() ![]() |
None of the above ......
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 473 ![]() ![]() ![]() |
Agree with dolphinboy. They crack around the bolt fixing points and break loose. I discarded mine on my Td6. Never noticed any difference and no problem on the MOT. That said they are there for a reason so best to repair if it turns out to be that. |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
+1
id already suggested that. ![]() |
I only read the plastic bit at the beginning of your post |
Zircon, you are right but u called it a water shield. |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
Yes to this, ours did the exact same thing recently, sounded awful when driving the car as well! Backing shield had rusted and the bolts had pulled through the plate. |
Permission to laugh if it turns out to be something else ? |
They're often referred to as splash guards, grit guards, water shields, heat shields and more often than not, rattly bit of tin on the back of the brake disc. ![]() In different vehicle manufacturers parts catalogues, they're given all sorts of names. |
