![]() | Home > Maintenance & Mods (L322) > Hit standing water fast & hard |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
This is up to 05 model, different for later models but same idea
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
that's true. the large chains wont let you under the ramp yourself. The smaller independent ones on the other hand normally don't mind if you ask nicely. Just go in first thing or any other time they're not busy. |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
Update on cause : checked everything obvious on Sunday with no luck. Got it on a ramp today and established the heat shied "tin foil" relating to the exhaust situated roughly in the centre of the car had been completely bashed about and was rubbing on the centre propshaft. Took a couple of goes to fix as "tin foil" split and had lost all its rigidity. Seems ok now but suspect a new one will be required. Thanks for everyone's input and looking at how this is designed I suspect this is quite a common issue if someone like me thinks his car can aquaplane like a jet ski. |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
What I said |
