Home > Off Topic - Other Cars > Tesla |
I would bet the ones using it to play horsey or doing motorway trips all day are well outweighed by those using it for commuting less than 50miles a day.
11th Dec 2015 3:10pm |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
I think more than a fair few will use the FFRRs/LRs to travel longer distances. Even if many don't do it often, many will want to use them for a holiday or road trip. It's what they do best.
My complaint with them is not so much down to processor speed (though that is an issue), but very much the UI. For example, when my FL2 was written off, we were given a 2013 one on hire. To change tracks on an MP3 CD in my old one, I'd simply use the wheel to scroll through the folders, and press to select - very simple, very quick. It was most annoying, when to do the same on the 2013 one, I had to go through menus on the touchscreen, also having to interupt the navigation (which, admittedly, I rarely use), to do the same thing. The fact it was slow to respond added to the issue. The thing is that I want the UI to be set up in a virtually permanent state (screen burn alert...). I want stereo and climate control controls to all be visible together, and to not interfere with each other. Once you've done that, you've pretty much lost any benefits of the touchscreen, so a reliable, tactile button is then always better, IMO.
Trouble here would be that running higher current/voltage wires around the vehicle would likely mean more interference and electrical issues. It's always the 12v braking systems that cause trouble, and hell do they cause trouble! Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver |
11th Dec 2015 3:23pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
12v braking system No thank you.........
11th Dec 2015 3:28pm |
Brake by wire should be a Bowden Cable not a bit of copper Yesterday I couldn't spell Engineer... Today I are one!
11th Dec 2015 3:29pm |
Not brake-by-wire, but just the switch, bulb and ABS electrical circuits. Visiting from DISCO3.CO.UK
11th Dec 2015 3:31pm |
