Home > Technical (L322) > TD6 Rad replacement |
Has anyone replaced theirs at all as i think some debris from the floods yesterday must have struck the rad and as its 10years old im happy its had a good life.
9th Dec 2015 9:00am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Yes it is that easy to remove, if your viscous fan is already missing, it should take no time at all. From memory you have to undo the 2 large clamping bolts at the top, ease the top of the rad towards the engine and lift! I do remember it being a tight squeeze past the intercooler pipes, but it can be done...... In fact I managed to remove mine with the fan and shroud still in place
9th Dec 2015 10:06am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1755 |
If the fan is off, it's a doddle to do
9th Dec 2015 10:13am |
Cheers guys.
9th Dec 2015 11:24am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8216 |
Any coolant will do, doesn't have to be BMW stuff, nothing special about it apart from the daft price, just got regular stuff in mine, used the long life stuff and it's been fine.... Pete
9th Dec 2015 4:21pm |
True but there are different colour coolants and different types. Think I'll hit el Wiki and check the specs 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
9th Dec 2015 5:14pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Been running on Halfords pink stuff for years/miles, no issues. .
9th Dec 2015 5:22pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
Just be warned that OAT fluid and earlier non OAT Ethylene Glycol fluid are incompatible.
9th Dec 2015 8:11pm |
Saint.V8's howto on rad replacement for his V8 is very similar to the TD6 and should give most clues
9th Dec 2015 10:00pm |
I'm guessing it's EG but I've contacted a local specialist to prove it all up for me as they can usually do it for less than 1/2 day of my work for most jobs they've done in the past so if it's not too silly on top of rad price I'll let them do it Monday so I can try and be back up in the lakes next week to help out for a day or two.
10th Dec 2015 12:11am |
Annoyingly I've been able to have a closer a look in what passes for daylight these days, and the vapour appears to be coming from just under what I'm sure is the egr cooler
12th Dec 2015 1:04pm |
See my thermostat howto for accessing the egr cooler
12th Dec 2015 3:23pm |
If it's he water pump I'll be mostly happy as its still under warranty and should mean I'll get it sorted quicker as provisionally booked in for 5th of Jan as they shut down for two weeks FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
12th Dec 2015 3:39pm |
Update and resolution!
6th Jan 2016 5:37am |
