Home > Technical (L322) > Reset Inspection warning |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 |
Its in the Wiki section |
28th Nov 2015 7:20pm |
dvb247 Member Since: 22 Nov 2015 Location: Cheshire Posts: 93 |
Have checked and it's only for the 2002 to 2004 model, mine is a 2005 ??
28th Nov 2015 7:49pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
Mine is MY 2005. The method in WIKI is what I have to use. Later models can be reset with a diagnostic tool such as Gap iiD. The tool doesn't cover 2005. John
28th Nov 2015 8:01pm |
From what I've just read, my car is a 4.2 Jag engine with touch screen nav, which means it can only be done using a diag program |
28th Nov 2015 8:58pm |
For clarity is your VIN number 5Axxxxxxxxxx or 6Axxxxxxxxxxx ? If the latter then you would be better listing your FF as 2006 as it helps with answering any queries you have. John
28th Nov 2015 10:19pm |
Not got the logbook back yet, can only find the SALLMAM number on the windscreen and under the bonnet on the strut. do you know where I can find it? |
28th Nov 2015 10:31pm |
It's the number at the bottom left of the screen. It's the rest of the number after SALLMAM.
28th Nov 2015 10:37pm |
Doh, sorry, yes it's a SALLMAM336A209***
28th Nov 2015 10:43pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Just for future clarity.
29th Nov 2015 1:01am |
Thank you |
29th Nov 2015 10:49am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
All 4.2’s are 6A> i.e. Jag engines signify 06> builds... |
29th Nov 2015 11:14am |
