Home > Technical (L322) > Reset Inspection warning
dvb247
United Kingdom 2006 Range Rover Autobiography 4.2 SC V8 Bonatti Grey
My 2005 FFRR has started showing the Inspection message on start up, I have tried to search for the sequence but can't find the one for my year of car?
PS it has an eye watering last service in August down South, I live in Cheshire so I'm not going to ask the Indy obviously, and I don't want a bill from a local Indy either!!
Post #359396 28th Nov 2015 6:58pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Its in the Wiki section Thumbs Up
Post #359400 28th Nov 2015 7:20pm
dvb247
Have checked and it's only for the 2002 to 2004 model, mine is a 2005 ??
Thanks for the Wiki area heads up, not noticed it before!!
Post #359403 28th Nov 2015 7:49pm
Weegie
Mine is MY 2005. The method in WIKI is what I have to use. Later models can be reset with a diagnostic tool such as Gap iiD. The tool doesn't cover 2005. John
GAP iiD BT
Post #359405 28th Nov 2015 8:01pm
dvb247
From what I've just read, my car is a 4.2 Jag engine with touch screen nav, which means it can only be done using a diag program Banging Head
Post #359420 28th Nov 2015 8:58pm
Weegie
For clarity is your VIN number 5Axxxxxxxxxx or 6Axxxxxxxxxxx ? If the latter then you would be better listing your FF as 2006 as it helps with answering any queries you have. John
GAP iiD BT
Post #359435 28th Nov 2015 10:19pm
dvb247
Not got the logbook back yet, can only find the SALLMAM number on the windscreen and under the bonnet on the strut. do you know where I can find it?
Post #359440 28th Nov 2015 10:31pm
Weegie
It's the number at the bottom left of the screen. It's the rest of the number after SALLMAM.
Did you ever discover if you have a tow bar or not? John
GAP iiD BT
Post #359442 28th Nov 2015 10:37pm
dvb247
Doh, sorry, yes it's a SALLMAM336A209***
Tow bar
No not yet, the weather is awful, will look tomorrow and see what's under the back bumper Thumbs Up
Post #359444 28th Nov 2015 10:43pm
Zirconblue
Just for future clarity.
cars built in late 2004 are '2005 model year' (they do have the touchscreen nav, but no external facelift) and can only be reset from the dash. They have vin's starting 5A
Cars built from the middle of 2005 onwards are '2006 model year' (they have the external facelift, with the headlamp wipers deleted) and can only be reset via a diagnostic tool. They have vin's starting 6A
SALLMAM is common to all L322's, from memory (a guess without looking it up) it breaks down to something like S= United Kingdom, AL = Land Rover, L=Solihull Plant, MA= Range Rover, M33= 5 door. You get the idea. the bit from 6A onwards is the actual serial number.
Post #359463 29th Nov 2015 1:01am
dvb247
Thank you Thumbs Up
Post #359497 29th Nov 2015 10:49am
All 4.2’s are 6A> i.e. Jag engines signify 06> builds... Thumbs Up
Post #359503 29th Nov 2015 11:14am
