Home > Technical (L322) > Mirror lamp LED's
DannyH
England 2002 Range Rover HSE 4.4 V8 Zambezi Silver
yeah go for a resistor, less heat generated than the bulb. Dan
2002 Zambezi Silver
Men And Motors RR Quote - It's like having wheels fitted to your living room!
Post #357822 20th Nov 2015 10:40am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
No need for a separate resistor if you get the right type of led bulb. Look for "canbus" bulbs when searching on e-bay etc. These have a small load resistor built in. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #358185 23rd Nov 2015 2:19am
that has been mentioned...mine were supposed to be canbus but didnt work , hence my solution... ... - .- -.
Post #358198 23rd Nov 2015 8:09am
wayneg
I cant see where that has been mentioned IE canbus bulbs. Was only trying to help. Get proper canbus bulbs and they WILL have a load resistor built in 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #358200 23rd Nov 2015 8:17am
Ivor's expired halfords link was for proper expensive canbus bulbs , thats what i meant by 'mentioned'....
these were the ones i got which also say 'canbus' ...they didnt work until i loaded them with one of the old bulbs..
the mirror lights seem to be picky at which canbus bulb will work or not .. ... - .- -.
Post #358204 23rd Nov 2015 8:52am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Somehow I found a set that work in the mirrors. I had an extra set of LED bulbs from my M5 that happened to be the same socket. Put them in and low and behold work great. Light up when locking/unlocking, dim on/off, the whole nine. Tried another set in the mirrors before the set that work and no dice. No idea but I'm not complaining...looks SO much better and updated. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #358238 23rd Nov 2015 1:11pm
boatsandy1966
United Kingdom 2004 Range Rover Vogue SE Td6 Adriatic Blue
has anyone changed the puddle lights in the mirrors for the projection type with the logo on at all ??? 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace
Post #362961 19th Dec 2015 5:33pm
the logo ones are sized for the bottom of the doors which makes them to big for the mirror lights.....i suppose you could fettle them in somehow. ... - .- -.
Post #362965 19th Dec 2015 6:07pm
I reckon they would be too far away for a defined image in the mirrors Stan...
Post #362992 20th Dec 2015 1:20am
agreed craig, the logo would be up the door somewhat.. ... - .- -.
Post #363013 20th Dec 2015 8:07am
Rangie in oz
United Kingdom 2003 Range Rover Vogue Td6 Epsom Green
Hi, I got an interior LED kit from xenon bulbs, great bulbs, all phillips as well, did the number plate and front side lights as well, no errors at all.
I also got some projector LED's (not logo) for the mirrors, as mentioned they just flickered once so did craigs tip and wired them into the puddle lamp in the bottom of the door, worked a treat Very Happy
great info on here as usual Very Happy 03 TD6 vogue....Epsom, very nice
03 TD6 se....gone Sad
94 Vogue se....gone Sad
Post #363467 22nd Dec 2015 12:30pm
