![]() | Home > Technical (L322) > Air suspension problem |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
Could be a height sensor playing up, bring up live values from them and go for a drive round, see what they do, they won't be the same as it depends on the sensor but the differences between them should stay the same.... Pete
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
No where has he said either end drops, he says they are rising to off road... how does a leak cause that...????? Pete
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Sounds like height sensors may be sticking. They can get rusty and stiff in action. They are pretty flimsy devices. I had problems with one of mine so I took it off and used a bit of WD40 on the joints and loosened them up. that worked as a temporary repair and confirmed the problem before I bought new units (very cheap - about £25). I don't think it would show up as a fault either, as they system is actually working but just fooled into knowing the actual height of each corner as the sensors are not operating correctly.
jeffshaw Member Since: 05 Oct 2014 Location: Northern Ireland Posts: 32 ![]() ![]() |
Cheers all, will take a look over the next few days |
![]() ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
The sensors are about £50 now for genuine rears and £70 for the front ones...
£25 ? .
Yes Joe, you are right. I paid about £25 for my rear ones. There were not original equipment but they only work as a measuring device after all. They are not a highly stressed component |
Mikeyjd, where did you get them, I couldn't find any pattern ones when I needed one and as you say they are just a cheap hall sensor, nothing special about them!! Pete
Have a look at these people Pete, I used them for a genuine rear wiper arm, nothing but good |
Cheers for that, just bought the other two for mine as I dare say they will go soon... less than £50 for both delivered and they appear to be genuine parts...
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Rears sensors are about £25 and fronts for Sport's and Disco's are £25 to. Full Fat fronts are circa £60 just been through that pain! Mine was a blue one! |
^^ http://www.autopost.co.uk/t/range-rover/ra...suspension
