Home > Technical (L322) > Air suspension problem
jeffshaw
Air suspension has been messing about for the while in that it was slow to raise. Purchased a compressor repair kit and fitted it. Now it likes to raise to full height at the rear but not at the front. Sometimes it will raise the front to standard and sometimes not. Looks like a dragster and sometimes is extemely hard ride. Then when you get out it seems as if it is venting from the front drivers wheel then sometimes it will raise the front. Plugged in two diagnostics machines and no faults found. Sometimes it will come up with the inactive warning as well. Don't just want to throw money at it until I find the problem. Any ideas??? Stuck valve of something ???
Thanks
Post #356094 10th Nov 2015 4:16pm
Could be a height sensor playing up, bring up live values from them and go for a drive round, see what they do, they won't be the same as it depends on the sensor but the differences between them should stay the same.... Pete
Post #356098 10th Nov 2015 4:38pm
miggit
Shocked Sounds like you've a hole in ya bag Shocked
But could also be a fault with the front valve block, that is located behind the plastic wheel arch cover on the drivers side, might pay you to remove the cover and just check the valve block for any obvious faults / leaks, if that is OK then I would say it's safe to say that the air bag / strut is holed. Another thing that you could try is a strong fairy liquid solution sprayed around the air bag, if there is a hole then you'll get lots of bubbles Shocked
Good luck Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #356102 10th Nov 2015 4:41pm
No where has he said either end drops, he says they are rising to off road... how does a leak cause that...????? Pete
Post #356118 10th Nov 2015 6:14pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Sounds like height sensors may be sticking. They can get rusty and stiff in action. They are pretty flimsy devices. I had problems with one of mine so I took it off and used a bit of WD40 on the joints and loosened them up. that worked as a temporary repair and confirmed the problem before I bought new units (very cheap - about £25). I don't think it would show up as a fault either, as they system is actually working but just fooled into knowing the actual height of each corner as the sensors are not operating correctly.
I aslo had a similar problem at the rear once, when one of the units broke. (the metal "leg" separated from the plastic end piece). I managed a quick repair bodge by wiring everything together with with a piece of copper wire). Remember, the height sensors only measure height. They don't perform any other suspension function, so don't have much strength in them
I have had leaking airbags in the past. Any sizeable leak will normal make an audible hissing sound (especially at full height). No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #356131 10th Nov 2015 6:58pm
jeffshaw
Cheers all, will take a look over the next few days
Post #356137 10th Nov 2015 7:27pm
miggit
Re: Air suspension problem
Shocked That sounds like a leak to me Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #356143 10th Nov 2015 7:47pm
The sensors are about £50 now for genuine rears and £70 for the front ones...
All FF's will at times, vent from the front or back when you have got out and shut the door, it means the suspension is working properly and levelling itself, what he heard was totally normal.... Pete
Post #356167 10th Nov 2015 10:02pm
£25 ? .
Post #356169 10th Nov 2015 10:04pm
Mikeyjd
Yes Joe, you are right. I paid about £25 for my rear ones. There were not original equipment but they only work as a measuring device after all. They are not a highly stressed component Smile No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #356311 11th Nov 2015 6:39pm
Mikeyjd, where did you get them, I couldn't find any pattern ones when I needed one and as you say they are just a cheap hall sensor, nothing special about them!! Pete
Post #356318 11th Nov 2015 7:53pm
miggit
Have a look at these people Pete, I used them for a genuine rear wiper arm, nothing but good Thumbs Up
http://www.autopost.co.uk/t/range-rover/ra...suspension Yesterday I couldn't spell Engineer... Today I are one!
Post #356340 11th Nov 2015 10:46pm
Cheers for that, just bought the other two for mine as I dare say they will go soon... less than £50 for both delivered and they appear to be genuine parts...
Top job
Thumbs Up Thumbs Up Thumbs Up Pete
Post #356362 12th Nov 2015 12:11am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Rears sensors are about £25 and fronts for Sport's and Disco's are £25 to. Full Fat fronts are circa £60 just been through that pain! Mine was a blue one! Smile
Post #356377 12th Nov 2015 8:18am
miggit
^^ http://www.autopost.co.uk/t/range-rover/ra...suspension
Whistle £18.16 + vat Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #356438 12th Nov 2015 12:31pm
