Home > General (L405) > 7 foot width restrictions
Page 1 of 3 123>
Shakman
Can a L405 RR get through a 7ft width restriction?
The literature says with wing mirrors out the car is 2.2 meters wide = 7.22 feet. What is width with mirrors folded in?
I presume the height of the wing mirror location probably means they are not an issue with regards to the bollards, its more simply the width of the track. Are surround sound cameras useful in this instance?
All feedback very much appreciated.
Post #356193 11th Nov 2015 1:44am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Width with mirrors folded in is 2.073, that's more than 2" inside 7 feet, 1 inch each side would be interesting at 70 mph. letters not necessarily in the right order
Post #356201 11th Nov 2015 8:37am
pjb
1" either side at 5mph - I would be worried if a regular occurence, as one day you will 1" out Exclamation Paul
L405 now sold
Post #356202 11th Nov 2015 8:57am
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
Our L405 is parked in an open fronted barn the entrance to which is between oak posts which are 7ft 4ins apart. I would not want to try to go through a narrower gap on a regular basis.
Post #356213 11th Nov 2015 9:38am
NormanP
United Kingdom 2014 Range Rover Vogue TDV6 Aintree Green
7ft is 2134 mm. If the 7ft is just a kerb, then no problem. The track is 1690, so from outer tyre wall to outer tyre wall is about 1950. The surround cameras are really helpful and the Kerb View will show you the tyre walls at the front on either side. If you have to fold the mirrors the cameras still work, but of course as the camera is on the mirror the view is now outward and so won’t help you.
If the 7ft is between bollards or walls…well: the widest point of the body work (as shown on the diagram from the Handbook) is top of the wheel arch, which isn’t measured on the official dimensions in the Handbook: it looks to me to be about an additional 40mm out beyond the tyre (on each side), giving a total bodywidth of 2110. That looks to me to be slightly more the width at the mirrors if they are folded, about 2070 (folding the mirrors saves about 75mm each side). So for a 7ft gap you have 12mm clearance on each side Shocked . Hope you are a good driver. Er…why don’t you try it and let us know how you get on? Twisted Evil
 Norman
Current LR: L405 Vogue TDV6 (MY 2014) Aintree Green/ Ivory interior
Past LR: L322 Vogue 4.4 V8 (2002); Discovery series1 V8 (1995)
Post #356219 11th Nov 2015 10:09am
Doodle
Agree about vulnerability top of wheel arches in tight situations. Always get hedge scratches there and needs some form of rubber wing protector perhaps.
Did you mean 40mm rather than 400. It's a man thing overstating length Rolling with laughter
Post #356246 11th Nov 2015 12:43pm
NormanP
Yes typo thanks, fixed. Norman
Post #356253 11th Nov 2015 1:23pm
CS
My (single) garage door must be about 7' wide and with mirrors folded there was about an inch on either side of a 405. I found that a bit tight for comfort, the 322 is much more manageable and I agree with pjb that this has potential to add stress to the 405 ownership experience. It was quite a squeeze to get in and out once the car was inside too. Perhaps the new technology where the car can park itself in a tight space with the 'driver' outside the car will help, but Q what happens if the battery goes flat when the car is in the garage.
The 405 mirrors may look better and cause less wind noise, but they seemed to me to fold in less and be longer, with the shape also causing a swirl effect that draws drips of water on to the mirror glass. Only Range Rovers since 1988
Post #356307 11th Nov 2015 7:16pm
Shakman
Hmmm ....my rat run .... think I need Land Rover to create a Park Assist function for width restrictions !
Post #356322 11th Nov 2015 9:06pm
Might be worth a tape measure to see if it really is 7'
I wouldn't fancy it on a regular basis Embarassed
Post #356327 11th Nov 2015 9:41pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
I think i would have a midnight removal session !!
Post #356367 12th Nov 2015 1:28am
Dixy
As it is legal to take a 7' through there, I bet the bollards are at least 7'6" apart. letters not necessarily in the right order
Post #356375 12th Nov 2015 8:49am
ebajema
Have a look to see if the surround cameras would work if you can get a test drive car with it. I'm assuming that you are still looking to buy one and want to make sure if this works ??
Also have a look at the bollard width as suggested to see what it really is. If it is (substantially) more then I wouldn't worry about it, if it is really tight it means slowing down a lot to get through. I would also check the kerb to kerb distance and make sure your wheels aren't coming too close there either !!!
Why is that restriction there, is it to warn for a more "solid" restriction like an old archway or such ?????
It is not nice to be so close on width but also it is not the end of the world if the detour is a much longer journey !! MY 2010 5.0 SC Galway green and sand interior!!
Post #356376 12th Nov 2015 9:15am
I'd be inclined to measure the width of your car at the height of the bollards accurately and then measure the actual gap between the bollards.
You do realise that if your car does fit and you use the road regularly some halfwit council jobsworth will appear as if by magic and reduce the gap to 6ft 6in. Very Happy
Post #356395 12th Nov 2015 10:34am
As the restriction is in both directions, I would suspect that it's merely to prevent larger & commercial vehicles using the route through a residential neighbourhood
The one on the other side looks like it has already been hit by something.
I also like all the other bollards visible around the outside as some people must have made a detour over the pavement in the past
Post #356397 12th Nov 2015 10:47am
Page 1 of 3 123>
