![]() | Home > General (L405) > 7 foot width restrictions |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1105 ![]() ![]() |
Width with mirrors folded in is 2.073, that's more than 2" inside 7 feet, 1 inch each side would be interesting at 70 mph. letters not necessarily in the right order |
pjb Member Since: 15 Feb 2010 Location: Sunny Oxon Posts: 244 ![]() ![]() |
1" either side at 5mph - I would be worried if a regular occurence, as one day you will 1" out |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
Our L405 is parked in an open fronted barn the entrance to which is between oak posts which are 7ft 4ins apart. I would not want to try to go through a narrower gap on a regular basis. |
NormanP Member Since: 15 Mar 2013 Location: Oxford Posts: 136 ![]() ![]() ![]() |
7ft is 2134 mm. If the 7ft is just a kerb, then no problem. The track is 1690, so from outer tyre wall to outer tyre wall is about 1950. The surround cameras are really helpful and the Kerb View will show you the tyre walls at the front on either side. If you have to fold the mirrors the cameras still work, but of course as the camera is on the mirror the view is now outward and so won’t help you.
Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127 ![]() ![]() |
Agree about vulnerability top of wheel arches in tight situations. Always get hedge scratches there and needs some form of rubber wing protector perhaps.
Yes typo thanks, fixed. Norman
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
My (single) garage door must be about 7' wide and with mirrors folded there was about an inch on either side of a 405. I found that a bit tight for comfort, the 322 is much more manageable and I agree with pjb that this has potential to add stress to the 405 ownership experience. It was quite a squeeze to get in and out once the car was inside too. Perhaps the new technology where the car can park itself in a tight space with the 'driver' outside the car will help, but Q what happens if the battery goes flat when the car is in the garage.
Shakman Member Since: 08 Nov 2015 Location: London Posts: 54 ![]() ![]() |
Hmmm ....my rat run .... think I need Land Rover to create a Park Assist function for width restrictions !
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
Might be worth a tape measure to see if it really is 7'
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1460 ![]() ![]() ![]() |
I think i would have a midnight removal session !! |
As it is legal to take a 7' through there, I bet the bollards are at least 7'6" apart. letters not necessarily in the right order |
Have a look to see if the surround cameras would work if you can get a test drive car with it. I'm assuming that you are still looking to buy one and want to make sure if this works ??
I'd be inclined to measure the width of your car at the height of the bollards accurately and then measure the actual gap between the bollards.
As the restriction is in both directions, I would suspect that it's merely to prevent larger & commercial vehicles using the route through a residential neighbourhood The one on the other side looks like it has already been hit by something. I also like all the other bollards visible around the outside as some people must have made a detour over the pavement in the past |
