Home > Technical (L322) > Rear diff locked up 3.6TDV8? Problem.... |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
Quick check would be to jack both rear wheels up with the handbrake off. Spin one wheel, and the opposite side should spin the other way. If it does then the rear diff is working as it should. If it doesn't then there is a problem with the diff.
18th Oct 2015 7:42pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
the diff on the rear of the standard 3.6 is an open diff, there is an optional electronically locking option which works via a clutch pack built into the diff but this was rarely specified.
18th Oct 2015 7:59pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 608 |
Thanks fisha - very sensible suggestion - shows how little my brain is working at the moment.
18th Oct 2015 8:01pm |
^yep thats how it works, applies the brakes to the slipping wheel and directs torque to the wheel with the grip. There is nothing that can't be fixed with a hammer😜😜
18th Oct 2015 8:08pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Ed,
18th Oct 2015 8:15pm |
Be prepared for less and less coherent messages - currently sat in a pub...
18th Oct 2015 8:16pm |
Very much doubt it's a diff they either work or they don't if they don't it won't go anywhere........ Pete
18th Oct 2015 8:19pm |
Cheers Pete - was wondering how long it would take you to chip in.
18th Oct 2015 8:24pm |
yeah, the noise was like the HDC but it thunked....!!! a bit more positive and mechanical sounding.... darn difficult to describe a noise....!!!!!! Pete
18th Oct 2015 8:38pm |
Sounds (sorry no pun intended but I'm waiting for 20GB of footage to copy onto the laptop so slowly working through the pints) like it might be an ABS sensor if yours did sound more mechanical as I would definitely describe mine as mechanical.
18th Oct 2015 8:48pm |
Name rings a bell, say hello to Joe for me...
18th Oct 2015 9:51pm |
Funnily enough I've had the opposite. Wrote off two in the lakes (Grabber ATs) and then another one in Surrey. Sidewalls seem to be mush in 255/55R19. Found the Wrangler Duratracs to have much better tread pattern and (holding on hard to the sideboard here) have survived Sarn Helen, Brechfa, more Brechfa and Strata over the last three days. Plus some other random stuff in between.
18th Oct 2015 10:44pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2470 |
If the centre diff is locked then the rear inside wheel is the most likely to spin when turning to relieve front-rear wind-up . |
19th Oct 2015 12:06am |
Well slight update.
19th Oct 2015 1:34pm |
