Home > Maintenance & Mods (L322) > Fitting New Osram DRLs |
shinchan Member Since: 05 May 2015 Location: santiago de compostela Posts: 109 |
Also I added a new painted bar...
18th Oct 2015 10:21am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
The Canbus signal is different so won’t support it sir Don’t waste your time!
18th Oct 2015 10:46am |
Thanks Craig! I don´t like to wired this at turn lights.
18th Oct 2015 11:03am |
Thanks Pete, I've painted this with anti rust coat but you have reason, this will need a deep treatment! |
18th Oct 2015 11:10am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8289 |
There are lots of ignition live wires in the waterproof box under the bonnet, I needed one for the fans, just had a probe about with a meter till I found one then ran a relay from it... Pete
18th Oct 2015 11:30am |
Yes...there are a lot of wires!!
19th Oct 2015 12:10pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 |
great work. Been wanting to upgrade the stock fogs on my 2008 to LED but have not b/c I don't want to deal with the headache of splicing/tapping into wires/relays and the malfunction lights on the dash etc.
19th Oct 2015 2:38pm |
Finally, I've dismantled whole front for rewiring correctly. Osram´s permit a optional wiring to have a 80% of DRLs when position lights is enabled. Instead of connecting the brown wire to ground must be connected to positive, and the dimmer effect is achieved....I like this! Also I made the new wiring to so that the system can be removed without cutting wires.
22nd Oct 2015 12:50pm |
My "technique" to weld: First, I removed the pin from connector and retired the seal. I sanded the pin with a file and insert the wire, then weld it. Insert the pin into connector and seal. Secure with strip.
22nd Oct 2015 1:11pm |
Pete, I found the appropriate wire! When ignition turned off allows DRLs 20 seconds courtesy and then off. Perfect! In the row, third connector (black)
I welded the blue wire... And power wire... Routing harness... Clean!!!
22nd Oct 2015 1:34pm |
Reinforcement bar mods...
22nd Oct 2015 3:14pm |
Now I work to embed the Osram fuse in the FFRR fuse box. I bought a Mondeo fuse box to try to do it.
22nd Oct 2015 3:26pm |
Small connector for position light (white). I left a wire ready for cornering lights. (grey)
22nd Oct 2015 3:38pm |
Hi, I approach to the end...
23rd Oct 2015 7:14pm |
