Home > Maintenance & Mods (L322) > Fitting New Osram DRLs
Page 2 of 4 <1234>
shinchan
Spain
Also I added a new painted bar...
Post #352847 18th Oct 2015 10:21am
shinchan
Spain
Cam-Tech-Craig wrote:
have you wired the cornering function sir?
Yes but I´ve not gotten it to work yet. I wired to pin 8 but the car is not equipped with cornering lights headlights, maybe that can activate through software.
Post #352851 18th Oct 2015 10:35am
The Canbus signal is different so won’t support it sir Rolling Eyes Don’t waste your time! Thumbs Up
And worth a quick mention Whistle When mine has a ctek connected, it makes the DRL’s flash on for 10secs once every few mins without the ignition turned on! Locked or unlocked! Just a strange phenomenon sir Whistle
Just incase it happens to yours too? It does happen to a customers car too Confused
Post #352853 18th Oct 2015 10:46am
shinchan
Spain
Thanks Craig! I don´t like to wired this at turn lights.
No flash problems!
Also I need to find the Terminal 15 (ignition).
Post #352859 18th Oct 2015 11:03am
shinchan
Spain
Haylands wrote:
Very nice, you have done a very thorough job, that rusty seam you cleaned off will re rust unless you have put some antirust treatment inside the box section to get into the seam, the rust is from the unpainted edges that were welded together...
Thanks Pete, I've painted this with anti rust coat but you have reason, this will need a deep treatment!
Post #352860 18th Oct 2015 11:10am
There are lots of ignition live wires in the waterproof box under the bonnet, I needed one for the fans, just had a probe about with a meter till I found one then ran a relay from it... Pete
Post #352863 18th Oct 2015 11:30am
shinchan
Spain
Yes...there are a lot of wires!!
Post #353062 19th Oct 2015 12:10pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
great work. Been wanting to upgrade the stock fogs on my 2008 to LED but have not b/c I don't want to deal with the headache of splicing/tapping into wires/relays and the malfunction lights on the dash etc.
The DRL is a bit of an odd shape/design no? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #353115 19th Oct 2015 2:38pm
shinchan
Spain
Finally, I've dismantled whole front for rewiring correctly. Osram´s permit a optional wiring to have a 80% of DRLs when position lights is enabled. Instead of connecting the brown wire to ground must be connected to positive, and the dimmer effect is achieved....I like this! Also I made the new wiring to so that the system can be removed without cutting wires.
At the moment I'm not interested to connect the cornering lights option at turnlights. This option allows turn on the fog light when turnlight is enabled, warnings also.
1- A new four poles Deutsch connector with two wires to fuse box (red/blue) and two wires to number 2 connector (yellow/black)
2- OEM bumper connector. I soldered the wires into de pins to Fog lights.
3- Wiring to fuse box
Post #353613 22nd Oct 2015 12:50pm
shinchan
Spain
My "technique" to weld: First, I removed the pin from connector and retired the seal. I sanded the pin with a file and insert the wire, then weld it. Insert the pin into connector and seal. Secure with strip.
Post #353618 22nd Oct 2015 1:11pm
shinchan
Spain
Pete, I found the appropriate wire! When ignition turned off allows DRLs 20 seconds courtesy and then off. Perfect!
In the row, third connector (black)
I welded the blue wire...
And power wire...
Routing harness...
Clean!!!
Post #353620 22nd Oct 2015 1:34pm
shinchan
Spain
Reinforcement bar mods...
Post #353636 22nd Oct 2015 3:14pm
shinchan
Spain
Now I work to embed the Osram fuse in the FFRR fuse box. I bought a Mondeo fuse box to try to do it.
Post #353640 22nd Oct 2015 3:26pm
shinchan
Spain
Small connector for position light (white). I left a wire ready for cornering lights. (grey)
Post #353644 22nd Oct 2015 3:38pm
shinchan
Spain
Hi, I approach to the end...
Today I made a small stainless steel plate to fix the out connectors and reinstalled all the front.
Post #353869 23rd Oct 2015 7:14pm
Page 2 of 4 <1234>
