Home > Maintenance & Mods (L322) > WINTER Protection to the extreme FFRR
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
If your like me & love your FFRR then here's what I have done to both FFRR we have
WAX OIL the entire chassis - masking up all the rubber components ( I used foil as its easy to shape & see - Rubber boots & Drive links etc )
REMEMBER - if you do this NEVER get under the car as the air suspension can lower at any time
use AXEL STANDS in the 4 side mount jacking points - raise car on max off road height - boot top & lower tail gate open - or do as I did use a work pit or car ramps - safety first.
Hint - warm Wax oil can in hot water for 20 minutes - add 10% white spirit to mix - use air compressor with pro sprayer set on narrow spray to get to the bits you are spraying - spray in even coats - drying time approx 1 hour in warm weather
again I hope this helps with your winter protection
Range Rover for life - look after her and she will look after you - FACT
both cars - every year since new - I spray coat again a light covering - extra protection - remember to coat Brake lines with Wax Oil - salt is bad news for them
Good luck with yours Thumbs Up
Post #352358 15th Oct 2015 10:04am
Top job, looks excellent and should help a lot... Thumbs Up
Keeping the boot or tailgate open doesn't effect the EAS, leaving a door open will prevent it from moving at all, i.e. self levelling, as you say, axle stands are a must though if you are going underneath... Pete
Post #352363 15th Oct 2015 11:07am
EmiratesA380
Hi Pete
Cheers - a lot of work but keeps the salt at bay
Shes got a mind of her own - like her in doors ! - say no more
Post #352366 15th Oct 2015 11:57am
proser
@Emirates777 - did you take the wheels off to get good access around these areas, or was it not needed ?? Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #352367 15th Oct 2015 12:13pm
EmiratesA380
Hi Mark ( proser )
I did this in 2 stages
1. Every six months I take the wheels off to clean and inspect the rear parking brakes on both cars ( as they can build up with brake dust ) - when wheels off I took off the discs & removed the stone shields to each - to Wax Oil in Black and lower suspension brackets & bolts.
DON'T TRY TO USE THE CLEAR Hammerite - when you spray the stuff you cant see it - and besides Black looks nicer
2. You can do this with all wheels on ( apart from the above ) - but ensure you mast all Rubber boots and Rubber joints up - Hammerite is not nice to these - it goes like a hard rubber when dry
The wheels & calipers could be covered with something like Cling film - but if the jobs worth doing DO IT RIGHT
FORGOT TO SAY - WEAR A GOOD FACE MASK & EYE PROTECTION !
Hope this helps - Fly Emirates Thumbs Up
I am thinking of doing the A380 next Bow down
Post #352368 15th Oct 2015 12:40pm
Don't tell me the A380 has rust issues..... Shocked Shocked Shocked Pete
Post #352371 15th Oct 2015 12:49pm
proser
Thanks Thumbs Up Regards
Mark
2012 Westminster
Post #352372 15th Oct 2015 12:57pm
EmiratesA380
Hi Pete & Mark
forgot to post this -
if you want to go down the route I did - Don't forget to take off both Rear & Front bumpers
behind them are the Mounting brackets - these will go rusty ( have a look at yours ) - by Spraying Hammerite over them they are weather sealed for life - NO MORE RUSTY BOLTS
Oh - I haven't wash the car for a month hence the Censored on her in picture ( pic shows Lower rear tail gate & bumper )
Again - hope this is helpful to you all
see you on board sometime soon - Fly Emirates Thumbs Up
Post #352373 15th Oct 2015 1:25pm
proser
Thumbs Up Thumbs Up Regards
Mark
2012 Westminster
Post #352391 15th Oct 2015 3:47pm
EmiratesA380
Anyone reading this article
Please have a look at the Photo & Video Section ( god knows why its there ) - its titled KEYLESS ENTRY **** WARNING *****
We need to keep on top of this one
Thanks
Post #352452 15th Oct 2015 8:37pm
